Cosworth 4x4 boost pressure drops in high rpm
i have sierra cosworth 4x4 stage 3 with garrett t34 and original t34 actuator, i drive without original amal valve, i have boost controler which is closed.
Cars runs okl at 1,2 bar peak and 1 bar held pressure. But today without any reason turbo pressure drops from 1,2 bar to 0,8 bar at high rpm
please help because here in bulgaria there is no cossy specialist
sundera, actuators can wear out you know, especially when running significantly higher boost than they are designed for.
could also be a leak in your inlet system, a big change in ambient pressure, a fucked turbo, loads of things
how can understand if my turbo is fucked? at intercooler there is no motor oil
no, just replace the actuator with a -31 which is what you should really have been using for those boost pressures in the first place.
Dont turn the boost up,change the actuator or spring.Mine did the same,it was running a -34 and went limp so I got a brand new one,a -31 didnt check first.Luckily the new one is a alloy one so I just changed the spring back and lowered the boost.Ta daa 24psi flash and all was good.
if my actuator is bad i think that peak pressure should drop also. Why my pressure drops dramaticly in high rpms? My peak pressure is ok - 1,3 bar but in high rpms it drop to 1 bar sometimes to 0,9 bar. Is it possible actuator go wrong only in high rpm
no, they are sealed units.
http://www.cosworthpartsonline.co.uk/
brand new -31 for 70quid from motorsport-developments
Since he is not using a amal valve I wouldnt buy a -31 as its base pressure is lower and wont be able to produce the same boost as a -34 without bleeding. If you are getting a new actuatar, get another -34. Atleast that is my suggestion but you might as well ask Motorsport Developments for advice before purchase.
is it normal my boost pressure to be lower at 1st an second gear?
at second gear i have peak pressure 1,4 bar and in high rpm drop to 1,1 bar
could you tell me what is your pressure at different gears
my is
1st 1,3 peak - 1 bar hold
2 - 1,4peak - 1,1 hold
3 - 1,5peak - 1,2 hold
4 - same
5 - same
my is
4 - same
5 - same
CrOwSoN15
18
22-08-2015 10:24 PM
Anutternutter
21-08-2015 06:07 PM
