pectel loom question
been given a genuine 2wd cosworth pectel loom it the same as the standard one all except it hasnt got the 2 relays iam i missing sumit or am i just thick
thanks chris
thanks chris
Alot of them won't have relays as they would have been built for a race car with etas and relay in the centre console.
I.e all t6 looms from pectel come with a 16 way cpc connector and no relays.
Generally pin 1,2 & 3 on the cpc will be live, I.e coil, and ecu/inj and aux drivers
you could run these to relays if you required
obviously you'll have no fuel pump relay or control of the pump via the ecu unless p28 from the ecu is in the cpc.
Again as usually on race cars pump are controlled via the control panel
muz
30-09-2015 08:29 AM
