Injectors out of a Mondeo ST TDCI
remove the high pressure feed pipes, remove the electrical connectons and unscrew them out of the head. Make sure you mark which cylinder they came out of with something that will not be removed by the sonic cleaning process (not paint, it'll need to be etched on or engraved on).
if its to cure rough running and smoking on start up its not that simple I dont think.
I am suffering the above symptoms as do MANY others and it seems the only way is to have the injector properly refurbished (new o-ring, valve etc?) and then recoded. Just been quoted £650 by Feather Diesel in halifax (my local delphi agent). I've read horror stories of people having them refurbed cheaper by non-delphi agents and them failing pretty quick after.
I think my above quote includes checking/flushing the fuel system too.
Spelling Club King!
£650 is about right to be honest , i paid £692 to have new ones put in mine and recoded , each injector was £105 + vat i imagine then labour to take them out and put back in which was 1.5 hours and then recode them .
I've also heard that if you just get your own recond from anywhere other than delphi they only last about a year due to not having a new code generated .
wowk
30-03-2021 07:49 PM
