2wd cossie fans not working
as above noticed when sat in a little traffic the tempture was on the way up and no fans comming in . i got the car home and have checked the fuse and that is fine so i let it run on the drive to see if they would work and still no . what else can i check or could it be that is causing the problem
big floppy donkey dick
as above, pull plug off rad temp switch, bridge terminals with split pin (or wire)
if they work, temp sender,
if not, check fuse in fusebox, see if its melted the fusebox! very common!
make your own harness with relay setup, 4 pin, 30, 85, 86, 87 piece of piss
rog
04-09-2015 12:10 PM
CabrioTurbo
01-08-2015 11:04 AM
lockie
31-07-2015 10:03 PM
