Transit engine problem
Old May 6, 2010 | 07:34 PM
exup 05's Avatar
exup 05
Default Transit engine problem
Hi new poster here ,......can anyone help me with this problem its a 04 transit deisel .....it starts and ticks over no problem , but when you rev it it revs for a while but suddenly cuts out and heater plug light on dash comes on just before it dies ...thanks in advance for any help ...
Paul
ps ....i should add if you do get it to move it crawls along and eventually dies
Old May 6, 2010 | 08:41 PM
james kiely's Avatar
james kiely
more than likely its the flyby wire accelerator pedal ,they are known to give trouble ,i think you have to replace the accelerator pedal
Old May 6, 2010 | 08:52 PM
exup 05's Avatar
exup 05
Thanks James ,thats all i need to hear .............. will see if it is and report back ...thanks for the reply
Paul
Old May 6, 2010 | 09:00 PM
davecosworth's Avatar
davecosworth
IM BACK
as above but you can some times remove the side of them and give them a good clean out as they get full up with dirt dust all sorts worth ago have done a few like this
Old May 6, 2010 | 09:09 PM
james kiely
i didnt know you could clean them dave ,good call
Old May 6, 2010 | 09:15 PM
cosevo's Avatar
cosevo
had same problem with my old transit, defo sounds like accelerator pedal as above
Old May 6, 2010 | 09:20 PM
DazC's Avatar
DazC
As it cuts out, I would say it has nothing to do with the trottle pedal. It sounds like the symptoms caused by excess air gap on the crank position sensor. I'd try a new sensor but failing that you'll need it code reading.
Old May 6, 2010 | 09:32 PM
BRAM's Avatar
BRAM
Im on sorting one at work now its a 2.4, i got codes for the pump 1664 + 1563 (i think) and it tells you on ford etis to check the chain tensioner, when i did the tensioner and all guides need replacing.
Can't see why it would cut out because of the pedal.
Old May 6, 2010 | 09:40 PM
vaughant's Avatar
vaughant
If u knock ignition on/ off quick it cures it as a quick fix.glowplug light flashing is same as engine management on petrol car.these vans suffer from leccy/sensor gremlins all the time but should be cheap enough to fix.
Old May 6, 2010 | 09:45 PM
james kiely
i was going to say that as my brothers van has had this problem for about three years and you just learn to live with it ,you just have to be careful at junctions that you have power before you pull out
Old May 6, 2010 | 09:58 PM
vaughant's Avatar
vaughant
I shit myself at first as it was a customers van who wanted me to take it home at night for safe keep,I thought oh no!!!but as you said,after a day or two got used to it!!!
Old May 7, 2010 | 11:02 AM
exup 05's Avatar
exup 05
Ok gentlemen...took out accelerator pedal blew it and cleaned it ,put it back in same problem ticks over ok but rev it for 4 to 5 revs and suddenly cuts out then heator plug light on dash flashes after it cuts out ,....now ive noticed that the self primer pump if thats what it is comes on afterwards if you leave the ignition turned on after it cuts out , i did clean out the filter before this to rule it out it looked pretty clean too ,..so do you think it is a fuel problem
Old May 7, 2010 | 11:13 AM
james kiely
have a look on the transit forum mate ,i always felt it was an electrical problem ,as the bros van always cut out when you were coming top a stop when your foot was very lightly or off the throttle pedal.the fact the glow plug light comes on kind of eliminates fuel starvation other than caused by something electrical.has the problem changed in anyway since you replaced the pedal after cleaning?
Old May 7, 2010 | 11:22 AM
exup 05's Avatar
exup 05
Well James without touching anything after it cuts out ,you start it rev it and after about 4 revs of the pedal it cuts out ,does not seem any better after pedal went back in
Old May 7, 2010 | 01:14 PM
silver's Avatar
silver
Crank sensor, about Ł35 for a new one.
Old May 7, 2010 | 02:06 PM
exup 05's Avatar
exup 05
ok Silver ,...thats next on the list ....will change it and report back .
Old Jun 8, 2010 | 08:44 PM
exup 05's Avatar
exup 05
Sorry about the delay ,for anybody who is still intrested after getting codes read twice by different places ,they were comming up with things for the pump ,i eventually got the last lad to change the crank sensor thanks to you guys here for suggesting it ,and guess what ...it was the problem ,had to get a lot done besides that for the MOT so all going well now ...thanks again to you all for your help .................
Old Jun 9, 2010 | 01:51 PM
cossie.con's Avatar
cossie.con
Thumbs down
We had the same recently in our 03 TDCI engine works van. It turned out that it was the pump(common fault) The symptoms were that the van wil knock like mad (liked if you fill a diesel engine with lazy start) My understanding is that the baearing in the pump fails and sends swarf allroud the fuel system causing problems with all associated componants.Pump, injectors,tank,filter head and filter. Just a heads up to Tranny owners.
Old Sep 17, 2014 | 10:21 AM
Stegee84's Avatar
Stegee84
Default Transit 2.0tdci 2004
Mr transit likes to go into limp home mode when under load on a motor way. Glow light flashes turn it off then on again then ok if I so it again on motorway does it again under load.
Comes up with code PO251
Replaced the fuel metering replaced 2 injectors that was leaking back to much please somebody help as am stuck thanks in advanced Steve
Old Sep 17, 2014 | 04:24 PM
DazC's Avatar
DazC
P0251 - fuel pressure target cannot be reached.
Either you have restrictions in the fuel flow (blocked filter, tank stack pipe or drawing in a bit of air from a bad seal for example) or your fuel pump is defective. Either way your fuel system is struggling to make the required fuel pressure. Have the other 2 injectors been compared to the new injectors? Unlikely to be a problem but worth doing a leak off comparison to make sure they're all roughly even.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Mark RS
14
Aug 11, 2015 11:45 AM
vdubo7
Aug 2, 2015 08:17 PM
