Escort Cosworth Backfiring
Old 14-01-2005, 02:25 PM
Skiman
Skiman's Avatar
Default Escort Cosworth Backfiring
My escort cosworth when coming on full boost is backfiring like its a rally car, its the type of sound like a boost hose is off but they are all on securely...
Old 14-01-2005, 02:34 PM
RANJ
RANJ's Avatar
plugs ????
Old 14-01-2005, 02:51 PM
JohnnyB
JohnnyB's Avatar
I have seen this before, The CPS is getting the wrong signal. Maybe timing thingy has moved.
Old 14-01-2005, 02:52 PM
Skiman
Skiman's Avatar
so you think it could be the timing?
It seems weird tho, that all of a sudden that its started happenin, like one minute not, one minute happenin...
Old 14-01-2005, 02:55 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Faulty crank position sensor causes this problem starts at about 3500rpm?
Old 14-01-2005, 02:58 PM
Skiman
Skiman's Avatar
Yeah that sounds pretty much like it, once it hits about 9/10psi
Old 14-01-2005, 03:06 PM
Skiman
Skiman's Avatar
Can you jus disconnect this?and if so, where is it located.
Old 14-01-2005, 03:10 PM
JohnnyB
JohnnyB's Avatar
front crank pully
no you cannot disconnect it you need to fix the problem.
The one I was working on the pin on the front pully has fooked it and the pully had moved.
Old 14-01-2005, 03:11 PM
Skiman
Skiman's Avatar
that doesnt make any sense, the pully has fooed it and the pully had moved....what?lolol
Old 14-01-2005, 03:12 PM
Skiman
Skiman's Avatar
Its a weird one tho, cos if you disconnect the amal valve, it doesnt backfire???
Old 14-01-2005, 03:15 PM
JohnnyB
JohnnyB's Avatar
hmmm mabe not then
Mike Rainbird
Caraholic
Definitely this then. Jack car up and look underneath the bottom pulley on the engine, you will see a sensor bolted on this. It does connect with a multi-plug to the loom, and if you're lucky, it is just water in the plug (you can unplug it and remove the sensor from the car to see). If it is bone dry, then it is faulty and not water ingress causing the problem, if wet you obviously need to clean both halfs with a suitable electrical water repellant.
It is only Ł25 to replace if cleaning the plug doesn't work.
Old 14-01-2005, 03:23 PM
Skiman
Skiman's Avatar
Nice one, oh how the people on passionford can help out a lost fellow eh
Cheers Mike
Old 14-01-2005, 03:30 PM
Mike Rainbird
Caraholic
Make sure when refitting that you position in the same place. It could be that it has come loose even and is not reading the marks correctly or even has some dirt on the sensor preventing it from doing so.
Old 14-01-2005, 03:40 PM
Skiman
Skiman's Avatar
But you think the problem is probably this sensor?
Old 14-01-2005, 03:44 PM
Mike Rainbird
Caraholic
Absolutely. Had the same problem in April last year...
Old 14-01-2005, 03:48 PM
Skiman
Skiman's Avatar
lol righto, ill get it sorted 2nite then lol...cheers buddy, if you lived in northern ireland id take you out for a pint....
Old 14-01-2005, 03:49 PM
Mike Rainbird
Caraholic
I've pulled .
Old 14-01-2005, 03:55 PM
Billabong
Billabong's Avatar
I've pulled :rainbird:
As you can see, Mike is 'offline' -that's because he's on the phone to Ryan Air
Old 14-01-2005, 03:59 PM
Skiman
Skiman's Avatar
Old 14-01-2005, 04:01 PM
Smit
The 60ft Launch King
Smit's Avatar
only 45quid
http://www.bookryanair.com/skylights.../skylights.cgi
Old 14-01-2005, 04:02 PM
Skiman
Skiman's Avatar
Dont ffs
Old 14-01-2005, 04:04 PM
Billabong
Billabong's Avatar
You've obviously heard of the Ringmeister over the water then?
Old 14-01-2005, 04:06 PM
Mike Rainbird
Caraholic
I'm on my way, you'll recognise me by my stupid fluorescent yellow jacket .
Old 14-01-2005, 04:08 PM
GARETH T
GARETH T's Avatar
check the map sensor wire/plug/pipe aswell
Old 14-01-2005, 04:10 PM
Skiman
Skiman's Avatar
okey dokey....
Old 14-01-2005, 04:16 PM
Billabong
Billabong's Avatar
Old 14-01-2005, 04:23 PM
Mike Rainbird
Caraholic
That brings back memories, I bet most of the youngsters here won't get that (unlike me being an oldie ).
Old 14-01-2005, 04:33 PM
Billabong
Billabong's Avatar
I always liked the cartoons from that 'strange woman with two first names'
Old 14-01-2005, 05:11 PM
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
Id be checking the plugs as well and ENSURE they are AGPR 12PPs and NOTHING else. This model suffers from coilpack issues and they are heightened by incorrect plugs. Also check the connections to the plug in chip on the ecu, but only with IGNITION OFF
The above advice only relates to EEC IV Model ESCOS. As i recall thats what you had, but may be very wrong.
Old 14-01-2005, 05:19 PM
THE RADMAN
THE RADMAN's Avatar
whatever happened to touche' turtle? youre not the only oldie on here mike;lol
Old 14-01-2005, 05:29 PM
GARETH T
GARETH T's Avatar
i didnt even know it was a small turbo model so i could be very wrong,,, i can see its a small turbo now though
Old 14-01-2005, 05:41 PM
ESCYSCOTT
ESCYSCOTT's Avatar
Hi Ryan, have you had the car properly mapped yet since fitting the chip??? It could be that you haven't fitted it correctly or that it needs the fueling checked for that chip???
Old 14-01-2005, 05:48 PM
Skiman
Skiman's Avatar
It is a Small turbo version Stu,
Scott, havnt had it mapped yet, i guess i will hav to get it done asap.
Old 14-01-2005, 06:06 PM
whitneyd
whitneyd's Avatar
Does it have a chip cause mine has a problem of the chip getting loose after a while and I know it's loose because it does what your describing. when it comes on boost and starts to pull hard it's just enough to wiggle the chip and produce a poping backfire.
Old 14-01-2005, 07:49 PM
Administrator
Youve fitted a chip?
Have you done it properly?
Is it mapped for a 4bar fuel reg? If so did you fit it?
Old 16-01-2005, 12:32 PM
Administrator
Old 16-01-2005, 12:52 PM
Azrael
Azrael's Avatar
So you say one schould use only Motorcraft Plugs on this one? You say coilpacks are problematic? I ask because I bough mine with different plugs and tehy worked fine, not I have one from Ford and it still works fine no missfire but I prefer to expect the worst problems
Old 16-01-2005, 01:08 PM
Administrator
Yes, the system runs very oddly with some aftermarket plugs, and SPECIFICALLY champion C5 range...
Theres no reason not to use the std ones and they are probably the best quality available for the price
Old 16-01-2005, 01:18 PM
Disabled Account
Disabled Account's Avatar
Also, there is a Denso version of the Ford PP8 that is known
to work very well, quite cheap too
Dave Griffiths at Interpro often fits them to tuned Small Turbo
Es Cossie's.....allows a nice big gap to be used and NO misfires
Quick Reply: Escort Cosworth Backfiring
