Any roofers in the house?
Ive had a materials list handed to me for my garage project for the roof,
now, I think it looks like this guy is planning to build a fookin arc on top of my garage with how much timber he's asking for, steel I can work with, timber I fookin hate.
So, lets spec a roof,
the building, 10m x 8m, the pitch is 1.5m from the eaves height, the materials are going to be marley modern concrete tiles, I have three fooking massive girders in the roof, one at the ridge and one on each side half way down, so these are going to support the most weight, not that its going to be that heavy compared to a conventional house size which would just use wooden purlins.
RSJ's are 203 x 133 x 30's.
so what size timers would we use for the rafters on the whole?
I dont want anyone going over board "just to be safe" I want the correct calculations for the right size.
Im sick to death of being told to over spec something on this job when its not needed.
cheers
mark
cheers
mark
Is that 8m front to back with the roof rafters going front to back also? That is a low pitch, without the drawings or anythng id guess at around 22deg?
I agree with using girders as the purlins on that span, but why at the ridge i dont know...doesnt need it.
yes Lee, that is front to back, the 10 meter is the width, and yes the pitch is low (feckin council regs), I have no actual drawings for the roof.
for what ive been priced in just timber alone, I could buy steel for the job and make the whole roof frame in steel never mind fookin timber !
What about the ceiling joists? As you wont span 8m in one go, is he not installing a central girder to carry the ceiling joists?
he has specced a variation of 150x50's, 100x50's, 150x75's and 50x25's, and a lot of them.
We dont need a ceiling, so nothing needs to span the 8m, though I have put pillars in incase i decide to put steelwork in.
I have maintained I want the roof space open and free so I can do what I want with it.
Are the purlin girders/beams being sat on padstones and bolted down?
Tbh i thought i'd put it accross easy to understand?
Ah right, i then retract my statement over the ridge girder, as it will need this as you are not having ceiling joists to stop the spread of the walls with the load weight of the roof, so the roof needs to rely on being held up by its own structure and not rely on the down force of triangulation spread. I'd also say that i'd go 150x50 as the main rafters so that a good birds mouth cut, about a third depth, can be achieved onto the purlin beams to help stop spread.
