injection query
Old Apr 15, 2010 | 11:18 AM
Conor Harrington's Avatar
Conor Harrington
Question injection query
right was thinking on my megane before i sell there is a problem with the injection system.
sparks are fine
ht leads are good.
for tthe megeane they have pencil coil packs on each spark went by pulling of each one and the first 2 moving from right ot left killed the engine once removed.
what im confused about is when i pulled out the 3rd one the engine dropped slightly in revs but never stalled does this mean this that coil is faulty??
if anyone can advise on anythign to try that woudl eb great
cheers
conor
Old Apr 15, 2010 | 11:27 AM
ECU Monitor Enthusiast
You should only disconnect one at a time to test this by removing the low voltage connector.
If the revs drop or rougness occurs when you disconnect one coil, then this is normal.
If when you disconnect one coil, the engine see's no change then that cylinder isnt contributing to the power output.
This could be a coil, injection or valve problem otherwise.
You can do the same tests by disconnecting the injectors and work out if fuel or ignition is the problem.
However, disconnecting items can cause ecu fault codes to be registered that may or may not auto reset depending on the manufacturer.
Old Apr 15, 2010 | 11:32 AM
Conor Harrington
yeha thats what i dun 1 at a time first 2 killed the engine 3rd jsut dropped revs very slightly and 4th killed it aswell.
dont the test with the injectors that all have the same squirt pattern and are not bloked.
and had a diagnostics on it and said i believe clyinder 4 or somthing.
would the throttle body have anything to do with the problem?
jonnyenglish
Sep 21, 2015 07:31 AM
coscor86
Sep 20, 2015 01:21 PM
TomPengelly
13
Aug 22, 2015 06:38 PM
gingerturbo
Aug 11, 2015 09:44 PM
mick pearson
Aug 9, 2015 09:19 AM
