My 3dr on the rollers... What will it make??? update 25/04/10
Old 18-04-2010, 06:57 AM
  #81
bluntys1rsturbo
Boost addict
bluntys1rsturbo's Avatar
im sure that will get sorted and its in prob the best hands going to do so , would you consider upgrading the turbo or are you happy with how your current one performs on the road ?
Old 18-04-2010, 07:43 AM
  #82
t4 and greys
cosworth gimp
t4 and greys's Avatar
try taking yr exhaust housing off and i bet yr bottom dollar its cracked to buggery
or the pissflap ,sorry pennyflap (if internally gated ) isnt seating right mate
worth checking before you bin the tubby... or even just wack another housing on and try !!
Old 18-04-2010, 05:04 PM
  #83
COLEYST200
COLEYST200's Avatar
i might just do that mate as i have a old T3 turbo with a 48 on the back of it
Old 18-04-2010, 07:35 PM
  #84
BRAMMER
BRAMMER's Avatar
My .48 was crap and wouldn't boost above 21psi, was suggested that it was cracked and after inspection their was small cracks but after speaking to CR Turbo's they suggested the penny not seating correctly and i think they were right.
Old 25-04-2010, 09:03 AM
  #85
COLEYST200
COLEYST200's Avatar
Thanks for you in put well the car was going to go back to martin yesterday with my mates turbo on but when i had a look at my turbo it had 4 big cracks in the rear under the penny and were 2 of the cracks were it had moved the casting so the penny was not sitting down right . so i told martin the car would not be coming as it was clear were the fult was so when i got home from london yesterday i tuck the rear casting of and there was even more cracks inside but as look would have it i had a old T3 turbo so i had a look at the rear of that and it was spot on so off it come all cleaned up and on it went well to say wot a different car it is now im going to do some more testing today as on its first run the boost went of the clock which is 30psi on the gauge we think it hit abot 34psi so today it will be coming down to about 28psi . i will all so be giving martin a ring in the week to see when we car get the car back on the rollers for a power run its looking good now all so sins the turbo went back on it is now spinning round when the car is on tick over so im happy
Old 25-04-2010, 09:08 AM
  #86
dave cos4x4
dave cos4x4's Avatar
glad its sorted.
Old 25-04-2010, 09:18 AM
  #87
COLEYST200
COLEYST200's Avatar
i will try and get some photos up today so you can all see wot the problem was
Old 25-04-2010, 09:22 AM
  #88
t4 and greys
cosworth gimp
hahah weres my prize then
just glad its sorted mate ,have seen it a few times
time to wack up the boost and have it setup methinks ....enjoy
Old 25-04-2010, 09:37 AM
  #89
COLEYST200
COLEYST200's Avatar
OK you win this part of it but i think its only right you shair it with BRAMMER
Old 25-04-2010, 10:06 AM
  #90
t4 and greys
cosworth gimp
hahah cheers coley and brammer bottoms up lol!!!
like i said seen it a few times hahah ,had one personally that had cracked from pissflap right out to the external housing itself !!
obviously when cold wouldnt be too bad ,but as you know metal expands when warm ,causing more leaks
let me know what it does when its setup ...
this is why for me pf is the best forum bar none
Old 25-04-2010, 10:12 AM
  #91
COLEYST200
COLEYST200's Avatar
Thanks mate for your help i will put the grath up and see how got the bhp right
Old 25-04-2010, 10:17 AM
  #92
andy escos
andy escos's Avatar
good news im glad it looks like you found the problem ,it was good to catch up with you at pod last week
Old 25-04-2010, 10:22 AM
  #93
COLEYST200
COLEYST200's Avatar
it was nice to catch up mate but wot are you doing on here you need to get working on the car as the clock is ticking and its now 9.weeks to go befor it needs to be on the road . im happy with how its now running and as said i will update the post when it gose back on the rollers all the best andy
Old 25-04-2010, 10:38 AM
  #94
t4 and greys
cosworth gimp
cossies are addictive hahah you slate and hate them when they have all these little issues ,and feel like chucking the towel in ... But when they do run right ,even if just for a week it makes all the difference and renews your faith
you cant beat the oldskool punch and delivery of the yb motor anywere .......PERIOD
cheers for adding me to list too
Old 25-04-2010, 10:43 AM
  #95
COLEYST200
COLEYST200's Avatar
to right mate i love oldskool
Old 25-04-2010, 11:23 AM
  #96
scoooby slayer
scoooby slayer's Avatar
well done mate, its nice when its a cheap fix for a change
Old 25-04-2010, 03:11 PM
  #97
markk
markk's Avatar
and the reason why it cracked was running to much boost pressure for a small housing - time for an upgrade?
Old 25-04-2010, 03:32 PM
  #98
t4 and greys
cosworth gimp
show me any housing thats been used that doesnt have cracks !!
and personally i wouldnt ditch the .48 either ....... well only maybe for a shady wrc .55 jobby maybe ..
Old 25-04-2010, 05:59 PM
  #99
BRAMMER
BRAMMER's Avatar
Glad you got sorted mate
Old 25-04-2010, 06:04 PM
  #100
markk
markk's Avatar
how many do you want to see pal ?
running high boost in small housings is great for punch, but your turbo then becomes a consumable item.
Old 08-05-2010, 04:57 PM
  #101
stu21t
stu21t's Avatar
time to drag up an old thread.
my car doesnt make a lot of boost,
its spiking at 1.4/5 and dropping to 1.1/2bar
this is a fairly new T34.63 with a genuine garrett-34 actuator, 1/2 a hole of preload, but no hose connected to the actuator.
even if i bolt the wastegate shut it still doesnt make any more boost.
so i took the air filter hose off today,
with the engine running i can very easily stop the wheel from spinning, can spin it backwards a turn or 2, then when i let go it takes a while for it to catch up and spin the correct way again.
but if i rev it up to 1500 it spins quickly and i recon i could stop it, i can easily slow it down, but didnt wanna do a load of damage.
im about to take the turbo off, to have a look at the rear housing,
but when i had it off over xmas i had a look and couldnt see any cracks on it.
does it sound like the housings knackered? or wastegate not sealing properly?
or should you be able to stop the wheel at idle?
cheers
Old 08-05-2010, 05:26 PM
  #102
stu21t
stu21t's Avatar
right ive taken the downpipe off and cant find any cracks in the exhaust housing, the wastegate is sealed properly, with the actuator connected i cant move the flap at all.
so should i be able to stop the compressor wheel from moving with the car at idle?
and if i shouldnt, then why can i if there doesnt seem to be anything wrong with the exhaust housing?
lol
Old 08-05-2010, 05:48 PM
  #103
gibbo frst
gibbo frst's Avatar
my old one looked like it was sealing properly so i put a thin layer of paint around the edge of the penny where it would make contact with the housing then held it shut with the actuator and when opened you could see only half the paint had touched on the housing..
went back to turbo technics and they fixed it with an inconnel arm.. maybe worth a look..
Old 08-05-2010, 05:59 PM
  #104
stu21t
stu21t's Avatar
bloody good idea m8
im gunna give that a go now, ive got a white touch up stick.
Old 08-05-2010, 06:21 PM
  #105
Jay,
Sponsor
Jay,'s Avatar
agreed mark never seen the point in over spooling a turbo to this degree and add the fact that a t3 has run out of efficiency way before 28 psi
Old 08-05-2010, 06:47 PM
  #106
stu21t
stu21t's Avatar
you fucking star.
just put some white touch up paint on the penny, and with the actuator connected its only touching about 20% around the housing.
so off it goes to be repaired.
any idea how much?
Old 09-05-2010, 09:32 AM
  #107
gibbo frst
gibbo frst's Avatar
mine was done on waranty but im sure it said £110 for the inconnel arm on my .63 housing.. i was told it shouldnt bend so easily with that.. was at turbo technics i had it done probably 2 years ago....
TPM961
15-01-2018 10:50 AM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
Sierrasideways
08-10-2015 06:37 PM
Quick Reply: My 3dr on the rollers... What will it make??? update 25/04/10
