Cosworth running problem *Help needed*
Old Apr 11, 2010 | 01:51 PM
Nash's Avatar
Nash
Cake lover!
Default Cosworth running problem *Help needed*
2wd Cosworth running L8 ecu with wasted spark board. Brand new engine loom.
I put the car on the road last year and every now and then it would just cut out and not run. The car would start again after a couple of times cranking it over and run fine again for weeks.
I fitted a new battery the Friday before National day as the old one was knackered. The car ran without fault on the friday, really smooth with no miss fires, didnt cut out etc.
I came to the car on the Saturday morning and it just wouldnt start. I tried all the connections and still nothing, would just turn over and not fire. I swapped some bits off my 3dr that i knew worked like the Phase sensor, CPS and still nothing.
I then tried it and it fired and ran for about 5 seconds, then again for 15 seconds the next time, I fired it up again and ran for a minute + as it started to die i got under the back and the fuel pump was making a puffing noise. The next time i fired the car it started and idled fine and then was fine every time i turned it off and on again.
I went and drove the car but it now had a very faint missfire on constant Throttle, fine at WOT and acclerating upto the point of constant throttle at say 3000rpm, would idle fine aswell. I turned it off at a mates then as i drove home it was fine back to how it was the day before. I stopped on the way home switched it off and had a look around it, then as i drove the last bit home it was missing again. Then the car wouldnt start again the following morning and i havnt touched it since really.
I sent the loom off to get checked and that was fine. I have a new set of Ign amps to fit, fitted a new PF09. I have a new coil pack, phase sensor, map sensor, cps all to try if she wont run.
All the parts and sensors were new when i put the car together last year, Fuel pumps and fans were rewired aswell. Fuel pump was a brand new 044 i had done about 6000miles on.
I am just wondering if anyone has any ideas on what the fault could be?
I have posted it in here as it gets more views than the tech section.
Old Apr 11, 2010 | 01:57 PM
COLEYST200's Avatar
COLEYST200
iv just got over this same problem with my 3dr and it was down to the leads have a good look at them mate
Old Apr 11, 2010 | 01:59 PM
COLEYST200's Avatar
COLEYST200
have a look at my post today
https://passionford.com/forum/genera...d-at-last.html
Old Apr 11, 2010 | 08:49 PM
Nash's Avatar
Nash
Cake lover!
Cheers Coley, i checked the leads tonight and they are fine. They were brand new last year aswell. I fitted a new phase sensor and coil pack on tonight after i refitted the loom. The car is defo getting fuel but only has one spark when you first turn the engine over and then nothing when you crank it.
I will try another cps tomoro and check they are gapped correctly. Does anyone else have any ideas?
Old Apr 12, 2010 | 12:55 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
If its definitely not the loom? maybe look at the amal valve? on L8 it takes its power feed from the fuel pump relay (on a factory loom) and on mine i had similar wont start/fuel pump cut out issues caused by water shorting the connector as the amal valve connector isnt that well shielded at the valve from water due to nature of the amal valve pins.
When it was causing issues on mine it would also take out the other engine loom relay as the power supply comes from same source so was getting voltage dips all over and id imagine that wont help with running.
manuel boeckx
13
Oct 3, 2015 02:29 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
