3dr miss fire solved at last
Old Apr 10, 2010 | 10:33 PM
COLEYST200's Avatar
COLEYST200
Default 3dr miss fire solved at last
Well as some of you might know, about 3 weeks back i gave up on my 3dr and booked it into REYLAND which it goes in on tusday. Well i was down at a brakers yard today sorting some stuff for my focos build when a focus came in to be broke! Well i just could not help myself i just had to have the coil pack off it for £10 . When i got home i thought i would just see if it was this that was making the car back fire all the time so on it went and i went for a spin. It was 100% spot on so i fort time for the boost to go up a bit and as the tools were out. We put all covers back on and down the road we went... well it was as bad as ever . Back fireing like mad so we turned the boost down.... still the same shit so i thought to myself what have you done to it now to what it was like 30min before? To which i said we have put the covers on that covers the coil pack and leads! So off they came and the coil pack was put inside the motor bay and the leads were just hanging all over the motor. Off i went down the road .... Spot on ,so the boost went up a bit still ok ,the boost up a bit more still ok ,so it went up to 28psi and its still spot on!!! It turns out its the leads being so tight togever as the coil pack was beside the heater motor out of sight but very tight. Its now by the battery and running spot on. This back fire problem has been doing my head in for about 5 months now so to say im very happy is a understatement as the list of stuff i have swapped on the car is silly and runs into hundreds of pounds. So it will be nice for it to go to REYLAND and be running nice before martin starts work on it! We will just have see what martin can do with the car now
Old Apr 10, 2010 | 10:37 PM
COCHYN's Avatar
COCHYN
Christ, do you hate the "return" button on your keyboard?!
Good result
Old Apr 10, 2010 | 10:41 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Glad its sorted at last Colsey, I was close with an ignition fault
Old Apr 10, 2010 | 10:45 PM
COLEYST200's Avatar
COLEYST200
Good result
Sorry for the way i put it down on here but i've got Dyslexia
and thanks
Old Apr 10, 2010 | 10:46 PM
STAFFY OWNER's Avatar
STAFFY OWNER
Glad it's sorted mate. Often simple things like that are the hardest to diagnose, more often than not they are found purely by chance as yours was..
Old Apr 10, 2010 | 10:47 PM
COLEYST200's Avatar
COLEYST200
Thanks mate
Yes mate you were close . It was only by luck we found it but we did in the end
Old Apr 10, 2010 | 10:48 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
lol
glad you got it sorted fella,
beef
Old Apr 10, 2010 | 10:50 PM
COLEYST200's Avatar
COLEYST200
Tell me about it .....about 2 weeks back we had the car running in the garage in the dark to see if they were sparking but all was ok so thought it was ok.
Old Apr 10, 2010 | 10:52 PM
COLEYST200's Avatar
COLEYST200
Originally Posted by -beefy-
lol
beef
Thanks mate you and me both. You never know it might go up the strip next weekend
Old Apr 10, 2010 | 11:13 PM
STAFFY OWNER
tell me about it about 2 weeks back we had the car running in the garage in the dark to see if they were sparking but all was ok so fort it was ok
That's one of the most common sense things my dad taught me many years ago to find sparks arcing in the dark. You could look for obvious electrical faults all day long in daylight and never find them but once you look in the dark they are virtually jumping out at you. It's surprising how many people don't know this simple trick.
Old Apr 11, 2010 | 07:26 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Some good news for you at last
Hope all goes well at Martins on Tuesday
See you on the PF Stand at Central Day
Steve
Old Apr 11, 2010 | 08:38 AM
COLEYST200's Avatar
COLEYST200
Steve
thanks steve its been a long time coming getting it running right see on the stand mate
Old Apr 11, 2010 | 08:59 AM
dave cos4x4's Avatar
dave cos4x4
glad its all sorted.
Old Apr 11, 2010 | 09:02 AM
Rsmat's Avatar
Rsmat
glad you got it sorted mate....sounded a night mare at first for you.
Old Apr 11, 2010 | 09:23 AM
COLEYST200's Avatar
COLEYST200
thanks mate its so nice to have it running nice after all this time . it started about november last year so you can see it has done my head in . this is the list of stuff i have put on the car to try and find it
Plugs x 5 sets.........at just about very gap size
TP sensor
MAP sensor
AIR TEMP sensor
the blue sensor
Phaze sensor x2
Crank sencor
044 pump
New fuel fillter
Tank off to be checked
Pump rewire
STACK AFG to set the fueling up
oil change as the fuel was going it from the miss fire x 2
all the wires tested and retested
new crank pulley
Coil pack x 2
Fuel reg x 2
Injectors
Chip
ADD THAT LOT UP AND YOU WILL SEE HOW MUCH IV SPENT FINDING THIS FULT
Old Apr 11, 2010 | 09:40 AM
andy escos's Avatar
andy escos
glad to see you finally fixed it ian ill have to catch up with you sunday & have a good nose around your car at central
Old Apr 11, 2010 | 09:45 AM
KSA-Cossie's Avatar
KSA-Cossie
Nice fix m8.
Old Apr 11, 2010 | 09:56 AM
LHD220Turbo's Avatar
LHD220Turbo
TP sensor
MAP sensor
AIR TEMP sensor
the blue sensor
Phaze sensor x2
Crank sencor
044 pump
New fuel fillter
Pump rewire
new crank pulley
Coil pack x 2
Fuel reg x 2
Injectors
Chip
COLEYST200's Avatar
COLEYST200
thanks mate it will be nice to cach up it should all be set up and maped for sunday
Old Apr 11, 2010 | 09:57 AM
COLEYST200's Avatar
COLEYST200
Originally Posted by KSA-Cossie
Nice fix m8.
its all ways some fing you dont thing it could be it did my head in
Old Apr 11, 2010 | 09:58 AM
COLEYST200's Avatar
COLEYST200
Originally Posted by LHD220Turbo
Tell me about it
Old Apr 11, 2010 | 10:06 AM
RS500/364's Avatar
RS500/364
TP sensor
MAP sensor
AIR TEMP sensor
the blue sensor
Phaze sensor x2
Crank sencor
044 pump
New fuel fillter
Pump rewire
new crank pulley
Coil pack x 2
Fuel reg x 2
Injectors
Chip
You selling these 044!
Old Apr 11, 2010 | 10:16 AM
COLEYST200's Avatar
COLEYST200
No sorry mate all the spare parts will be put aside for my focos build and the bosch 044 pump went on as it turned out the one on the car was of a RS turbo and not up to the job
Old Apr 11, 2010 | 10:20 AM
TOMMY_RS's Avatar
TOMMY_RS
SHITE!
fucking hell mate u have been trying 2 sort it for ages glad its fixed now get out and enjoy it!
Old Apr 11, 2010 | 10:28 AM
COLEYST200's Avatar
COLEYST200
trust me im going to mate
Old Apr 11, 2010 | 11:22 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
So the misfire was caused by the leads being too close together??
Old Apr 11, 2010 | 11:30 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Thats how i read it
Steve
Old Apr 11, 2010 | 11:32 AM
COLEYST200's Avatar
COLEYST200
yes mate it seams that way
Old Apr 11, 2010 | 04:06 PM
BRAMMER's Avatar
BRAMMER
It's mad how these things go but i'm glad your all sorted
Old Apr 11, 2010 | 05:15 PM
im glad you have got it sorted fella. There is nothing worse than having a fault on your car and you cant find it. I bet you have been sitting at home on a night thinking what it could be through your head.
Old Apr 11, 2010 | 05:54 PM
markk's Avatar
markk
i bet the lead tops are arcing on that crap chrome cover you have on, more than the leads being close together.
Old Apr 11, 2010 | 06:06 PM
RWD_cossie_wil
Would make sense that markk, or arcing on the bulkhead cut-out if that's metal? Other thing I would change is the actuator for a genuine garrett one, Stu put up a very good post explaining why, I will have a look through for it.
Old Apr 11, 2010 | 06:08 PM
COLEYST200's Avatar
COLEYST200
tell me about it mate
Old Apr 11, 2010 | 06:20 PM
COLEYST200's Avatar
COLEYST200
hi mate the cover has not been on the car sins xmass as the amout of plugs that we have put in it and it still had the problem it must be down to the way the leads went throw the bulk head . the cover is back on now but the coil pack is now by the battery and working very good so im now happy . just got to see wot martin can now do with it
DixieTheKid
11
Jun 6, 2020 11:20 AM
gambo08
Feb 4, 2016 10:49 PM
martynhomer01
Oct 1, 2015 12:05 AM
Fil
Sep 30, 2015 12:08 PM
IainRS1700T
Sep 25, 2015 06:44 AM
