Advantages of using a coil pack instead of a Distributor?
12-01-2005, 05:26 PM
As above on a cossie managed rs turbo
12-01-2005, 05:32 PM
you can use a biger plug gap / better idle / you do away with things that brake down ie dizzy cap/ rotory arm / dizzy
12-01-2005, 05:37 PM
12-01-2005, 06:35 PM
Quote:
Originally Posted by NUTS RuS
12-01-2005, 06:58 PM
how much does it cost to do this on a cossie roughly ??
Is it much work to change and roughly how much would it be to do this?
12-01-2005, 07:22 PM
Cost me about £45 from the scrapyard for the Vauxhall coil pack.
12-01-2005, 07:25 PM
Team HOTHOT!
do u not own a big coat
12-01-2005, 07:27 PM
or a empty tool box
12-01-2005, 07:30 PM
12-01-2005, 07:34 PM
vauxhall coil pack
, ever wonder
12-01-2005, 07:40 PM
Vauxhall coil pack.
That'll be the problem then
12-01-2005, 07:45 PM
My car when built had only 1 bit of the original Rover wiring loom in it.
It was this bit of the loom that turned out to be faulty not the actual coil pack.
It soon ended up in the bin and a new loom made by MEFmotorsport and has performed without a single fault since
zetec ones are £38 new
12-01-2005, 07:49 PM
but thats a Ford bit
That would have been tooooo easy
01-11-2015 06:53 PM
A.t.p
23-10-2015 07:54 PM
jameswrx
Modellers Corner.
17
09-10-2015 08:26 PM
07-10-2015 12:56 PM
20/20 vision
29-09-2015 11:27 AM
advantage ,
advantages ,
advantges ,
coil ,
distribitors ,
distributor ,
fords ,
land ,
pack ,
packs ,
rover
