Dissertations suck donkey balls
This is why I am having second thoughts about doing a masters and definatly having a year out.
A lot of my research has come from a Masters Thesis on GSHPs and its 180 pages long.
FUCK THAT
My lowly degree one is 6000 words and 3000 words of that is Intro, Method, Aims, Conclusion and Abstract.
FUCK THAT
We looked at these for our office building to help with heating or even pre-heating hot water as part of our Carbon Commitment Reduction, but we couldn't cost justify them as it would have taken years to break even before we start to save anything. Pretty cool idea though...
There was a bit about these on one of the housey type programs a few days ago but i can't remember much about them - there that's my contribution, you can tell they made an impact on me.
That my good man is the problem.
However.....
When you factor the potential rises in fuel to fire conventional heating methods the pay back period will be much quicker - thats point people miss, unft the rise in fuel prices is a theory on its own depending on 'peak' conditions and also supply/demand.
Similalry when considering houses part of the pay back should be an increase in value of the house that sustainable heat and power generation will give rise to, the problem here though is the perception of the general public that sustainability isn't an issue that is or will affect them - wrong!!!!!!!
Finally and most interestingly the UK is well behind the times - this tech is almost 100 years old, in main land Europe - Germany, Sweden, Switzerland and so on its uptake is pretty significant so capital out lay is less.
Retrofitting them to exisiting housing stock ( the topic of my paper ) is not so much fun.
PassionBMW.com Member
I feel your pain! I did 15,000 words on how to practically implement the legislation contained within EU Commision Regulation 2042/2003 ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
I'm considering doing a masters, its not the dissertation thats putting me off though, its the £14k Cranfield Uni want to do it part time![Wall](https://passionford.com/forum/images/smilies/wall.gif)
Half considering doing a fulltime one at the local uni (£3k!) as I do shiftwork and could probably blag it enough attendance wise!
I personally think GSHP is a waste of time, no offence shings. They rely heavily on unsustainable fuel to power them and are relatively expensive. I think buildings should reduce the amount of heating needed by super insulation and make the most of passive means of heating. Just my tuppance worth.
I personally think GSHP is a waste of time, no offence shings. They rely heavily on unsustainable fuel to power them and are relatively expensive. I think buildings should reduce the amount of heating needed by super insulation and make the most of passive means of heating. Just my tuppance worth.![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
You're incorrect though in your opinion.
They do use electricty to power them correct, however the whole point is that for the electricty they use to power them they provide 2-3 times the amount of heat.
IE it would take 2-3 times the electricity to produce the same amount of heat.
Dont forget you can produce electricity from PV Cells and Wind Turbines.
If they dont work like that then they're not suitable for the application, it comes down to the design of the building and the method of heat extraction as to how well they work
They are expensive to buy and install I agree, at the moment, when fitting them retrospecticly however my point on potential future fuel costs increasing is how they become economically viable.
Where they really win is on new builds where planning would otherwise be prevented due to the sustainable requirements of government.
At this point they suddenly become viable - 10-20k installed which means you can build vs you cant.
ARGHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
I`m sorry I dont agree, I find them far too expensive in most cases, and when you factor in the high cost of PV and the small return in electricity it gives and the amount of electricity the GSHP uses its not viable. 10-20k would be far better spent using super insulation such as external wall insulation in new or retro fit, this negates the need for a high amount of heating. Then hot water can be supplied by solar thermal with maybe a back up wood or pellet boiler. All that will cost alot less than GSHP. Buildings need to be reducing their need for heating and utilising passive means and by super insulating and building air tight we can do that.
Redumbdancy
Just doing the conclusion to my 20k word dissertation on the "changing role of the quantity surveyor" Only got a week to finish.
Be glad when its all over but I'll be working 5 day weeks instead of 4!!
I'd be interested to read that... a topic that was suggest for me was The role of the M+E Contractor as Main Contractor - could it work?
But that seemed a bit to much like hard work.
Lol im fresh out about 3 year's ago, it's a struggle there's only so many words that can be said about direct online motor's and bloody squirrel cage motor's!! The bane of my life those things! Lmao
To answer your question - No it doesn't - from first hand expereince.
We worked as a subcontractor for a small sized M&E contractor on the University of Birmingham - it was an absolute nightmare of a job.
No idea about programming, cost, mangement or anything!! To be honest I wish I'd have thought of that topic - would have been interesting.
I did orginally go for "collusion in the construction industry" but realised when it came to interviewing, who was going to tell the truth? lol, so had to change it.
Good thing is, I have an assistant working with me who has a degree in Mathmatical Statistics. Its ace when she does all my standard deviation etc. Top hole, as they say.
To be honest mate, I dont think anything you choose to do a dissertation on is remotley interesting by the time you finish it.
That opinion differs from the experience of the guys I work for - I work for the worlds largest M+E Contractor and it the top 3 in the UK and they suggest otherwise and have been principle contractor on a number of jobs which ran better than conventional jobs.... that said I preffer being subby as no main contractor I have worked with yet has the slightest idea about M+E.. MUHAHAHAHAHAA
Which is why most subbies think main contractors are shit!
21
14-09-2015 06:38 PM
Mark V8
13-09-2015 09:34 AM
