fiesta 2002 mark 5 1.4 zetec
HI folks,I have a fiesta 1.4 zetec,first of all i had a not start problem,with managment light on,fault code showed LT/Ht fault coil pack,i replaced with new,whilst i decided i would replace the plugs and HT leads,(i bought this car with this fault i must ad)when i removed the ait box the rocker cover where the HT leads fit was full of water so was the plug holes,i pumped out the water before replacing the spark plugs,any way once fitting the new parts i have now manged to start the car but it runs very flat,will not idle,so i decided to check the injectors,on cranking with them removed from the engine i noted only number one and four are spraying,so i swapped 2 and 3 with 1 and four to check for faulty injector/blockage,injectors work find plugged into 1 and four,I am now a bit miffed,could this be a ecu fault,can anyone help.I am a qualified mechanic on hgv's and PLG's,but not working at the moment so its a kind of hobby.any pointer would be very helpfil and apreciated thanks kev,p.s big thansk to sparkys2turbo for giving me help to start new thread as i am new to this site.
grishenko45
09-09-2015 12:58 PM
andrewmctiernan
08-09-2015 03:05 PM
