bell and rotors
Almost definitely no bells needed, just the discs, there's two main bells according to spacing/number of bolts on sizes around this, just phone up and ask for some.
formerly beefy-rst-2
if i read that right gus your looking for a 10 mm reduction on your disc size ?
id gues the bell you have would be capeable with that , literally getting a smaller od disc ,
id check the clearance from top of pad to disc and have your brackets machined down accordingly if need be fella
beef
beef
B1mbo
im sure they will be fine, we changed disks on the rear of the escort cos from 315 to 330 and used the same grp a bell, but could be wrong with the new disk and bell arrangement, get some measurements off the 315 disk before you buy if you can
martin @ reyland would advise you best give him a call he wont mind measuring up
cheers for replys chaps
luca im on about the fronts not rears,
knew the brackets would need to be made again (will keep the ones i have now, so can run bigger disc if i wana)
dave thats why i asked, if moved calliper in 20mm would there be enough room on the disc? or would it hit bell
i will phone hi-spec in the morning, just wondered if anyone knew
Ah that's better, I understand now!
As far as I know the inner radius is the same, so you should be okk depending on the size you have, but as a simple guide i'd measure the edge of the cliper/pad to the edge of the bell, if you don't have 20mm then forget about it.
Dave/Gus the caliper wouldnt need to be moved in 20mm, only 10mm if going from 335 to 315. Think Radius and not Diameter with the caliper.
As for keeping the bells, that depends on the specification of the new rotors and the relevent pcd they require the bells to be
exactly, your losing 20mm overall
thats 10mm top and 10mm bottom, so the caliper will only need to move 10mm inwards.
and i dunno about hispec but wilwood only have to different bell sizes, so chances are youl just need new discs.
I have just done this (335 to 320) with my Compbrake kit to allow 16" wheels to be used on track.
Speak to NutRus.
If you wish to run the same caliper and pad you'll probably need a 7" bell instead of 8". New disks and bolts.
You should be able to get the caliper bracket machined down to bring in the caliper the appropriate amount (so no new brackets needed).
Speak to NutRus.
Speak to NutRus.
Speak to NutRus.
i will use new brackets tho as i hate mine
OrionRST200bhp
29-09-2015 08:30 PM
james kiely
28-08-2015 08:58 PM
