General timing question...
Old Mar 17, 2010 | 10:16 AM
Shonky's Avatar
Shonky
V6 Ka of Love
Default General timing question...
I've spaced the heads out on my v6 to lower the C/R for some boost which has caused a major timing issue which the standard ECU is not coping with particularly well, it looks very much like it's firing the injectors too soon or mechanically retarded depending on which way you look at it, would it make the most sense to knock the timing forward so it's mechanically closer to what the crank position sensor is seeing or just leave it and sort it all out electrically when the management goes on?
Old Mar 17, 2010 | 10:20 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
The standard ecu on that engine takes its timing input from the crank sender which hasnt changed.
sounds more likely you are getting a sync error between the cam and crank sensors, just use a vernier pulley to get the sync back to where it should be, or move onto your autronic which allows you to change it anyway.
Old Mar 17, 2010 | 10:43 AM
Shonky's Avatar
Shonky
V6 Ka of Love
Have you seen the price on a vernier... We'll (you lol) can sort it out on the Autronic
Just to keep you posted I'll be taking some time off work in the coming month to get a load of shit done on the car, I'll wire in the Autronic as much as I can and give you a shout on a few things if it's ok then we can sort the mapping out
If it helps my mate has an N/A 3.0 v6 with cams running Omex, I could possibly get a copy of the map to make it easier to set the timing up, cold start, idle and shit
Old Mar 17, 2010 | 11:26 AM
Chip's Avatar
Chip
Ok mate, sounds good.
Old Mar 17, 2010 | 11:49 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
which v6 ford are talking of here as you had to put the eec4 into service set mode after engine work to rest the ignition timing
Old Mar 17, 2010 | 11:50 AM
Chip's Avatar
Chip
Its a vauxhall v6 but in a KA
Old Mar 17, 2010 | 11:55 AM
Turbosystems
Super Moderator
I wonder why people never state the make when they ask questions
Old Mar 17, 2010 | 11:57 AM
Chip's Avatar
Chip
Yes it would have been useful
DAN@ADRIAN FLUX
Insurance
15
Jun 30, 2018 09:00 PM
Caddyshack
12
Sep 14, 2015 06:06 PM
CossieRich
30
Sep 8, 2015 10:08 PM
jameswrx
21
Aug 27, 2015 07:38 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
