request - 4x4 front coilover measurements needed
as title please folks ,
as the s1 will be running 4x4 fronts in the rear and i havent got fund to buy a set , i plan on fabbing up a mock pair of them to support the car,
so i need the overall lenght on the shock ( not worried if its adjusted atm ) from the bottom to the base of the thread at the top ,
length of the thread itself and size - m8,m10.ect
diamater of the tube nearest cpl mm will do ,
width beteween plates where it mounts to hub
size of plate and bolt spacing ,
basically the dimensions you would need to replicate peeps
if anyones got one off the car ect
or if anyone is close to middlesbrough and wouldnt mind me loaning one for a day or two to have a pair made up ,
much appriceated
beefy
much appriceated
beefy
guys i simply want somthing that will bolt to a 4x4 front hub , a tube and i plan on welding on a peice of threaded bar ( the same diameter as coilover top) to the top of it , ill put a nut above and below the top mount as a usual coilover ,
it will offer no shock absorbtion what so ever , its meerly for me to adjust the threaded rod so the wheel clears the arch ,and so i can roll the car on 4 wheels
beef
beef
ok i have done a drawing of what my shock is in sizes, top numbers are diameters and bottom are lengths ive also included a picture of my shock, now the hob stop is the same size as the thread diameter, but drawing doesnt show this due to the shock tapering in, but it shoudld give you an indication of whats needed
JoeyBoyden
04-01-2024 02:36 PM
track.focus'd
12-08-2015 05:53 PM
