Fiesta/Focus ST170
Fiesta/Focus ST170
I've been offered a cheap(ish) ST170 that is cat C and wondered if I could fit the engine into my Mk 3 XR2i track car. Does anyone know if this is possible in any way? Or am I opening a can of worms and in for a task beyond reason....
Thanks
Thanks
it does fit my mate has one if you have a zetec engined car it will basically fit in as although the engine is badged as a duratec it is actually essentially a 2.0 zetec with adifferent head the only problem you might have though is the vvti which could give you a headache or so im told but not 100% sure how much hassle it could be
OR! You can work it with a shift light or summit .. Bloke I know has an ST170 in his Kit car ..
i was looking to do this, and im sure the engine mount needs modifying, and you need an added pulley so the water pump goes the right way...there is a thread on here somewere on someone doing it, i know this because i saw it lastnight...
also im not 100% that the inlet manifold will fit because of the space between the bulkhead and engine, not 100% but just make sure because you dont wanna put it in then relise you gotta spend another grand on throttle bodies
hope it helps
hope it helps
Bam Bam Bam
Search for jimmyesh on www.fiestaturbo.com dude, he's done this (st170 engine, box, loom etc into mk3 fiesta). will be pretty much a walk through guide, problems discovered and how he's got round it!
He's sold it now but the the thread will still remain. It looked an awsome conversion!!
Bam Bam Bam
Seeing as im in a good mood i've found the thread for you...
http://www.fiestaturbo.com/forums/my...-anj-vt170163/
Do it!!
Do it!!
Andypandy260
23-09-2015 10:28 PM
