best diff for 2wd cosworth
Old 12-03-2010, 09:23 AM
  #81
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
This has only been a relatively recent development . I have also given them a front diff so they can do these as well (for the 4x4 Cosworths) .
Old 12-03-2010, 09:28 AM
  #82
R5FORD
R5FORD's Avatar
O well you fork the delivery costs and il buy one
Wheres my tracking number Mike
Old 12-03-2010, 11:52 AM
  #83
Jamie@FastFord
Jamie @ Fast Ford
Jamie@FastFord's Avatar
As has been said, the new Titan VC diff is the one to go for in my opinion - Bara who builds mine was full of praise for the quality of these compared to the Gripper .
Agreed. We've got a feature showing how to convert from the OE viscous diff to a Titan plated diff comming up in the next issue. Bernie at CTS was also very impressed with the Titan unit.
Old 12-03-2010, 12:18 PM
  #84
joffy
SLOW LEARNER
joffy's Avatar
mike are these just for 4x4s or are they available for 2wd??
Old 12-03-2010, 12:20 PM
  #85
Jamie@FastFord
Jamie @ Fast Ford
they've just released a 7.5in version for the 2wd. That's the one we just featured.
Old 12-03-2010, 12:33 PM
  #86
Mike Rainbird
Caraholic
Both the 7" and 7½" rears are available to go right now .
The 6½" front won't be ready until the summer.
Old 12-03-2010, 01:49 PM
  #87
Mike1
Mike1's Avatar
Good feature - will look out for that. Be good if you could get an example of all the different types available at some point in the future and test alongside each other ( like the Intercooler tests ).
After all it's a lot of money for Joe Average to fork out on one type over the other if he doesn't like it
Old 12-03-2010, 02:48 PM
  #88
Jamie@FastFord
Jamie @ Fast Ford
Originally Posted by Fudgey
the escort rs turbo uses a viscous diff, ie many plates in a sealed unit, but the cosies dont, do they?
i had the rear cover off my diff but im fooked if i can remember!
i thought they were planet gears?
The Cossie diff is also a viscous diff 'with plates in a sealed unit'. But you also need the sun and planet gears (the notoriously weak link on Cossie diffs, especially when running 2wd) to allow the wheels to turn indpendently of each other, i.e. not a locked diff or spool.
As one wheel slips the sun and planet gears try to work as they would normally in an open diff, but the drag created by the plates moving through the viscous fluid prevents this and means that both wheels are encouraged to turn with the same torque effort.
***forgot to mention, viscous pack is above sun/planet gears in that pic***
Old 12-03-2010, 04:21 PM
  #89
Touring Car Spares
Touring Car Spares's Avatar
30 plates used in the std cosworth VC , theyre good diffs and when tightened are a great item until you try and do the Traffic light grand prix with it !
Titan have been messing about with their sintered diff for 2 years now , i still wonder if it will ever be made for the 7.5" Diff to be honest .
Old 12-03-2010, 06:25 PM
  #90
Mike Rainbird
Caraholic
see above, they are on the shelf ready to go .
Old 12-03-2010, 06:26 PM
  #91
Jamie@FastFord
Jamie @ Fast Ford
They have mate. Only just come out. I've got one for my project Saph and I think Mike is on about getting one for his Escort. (Although I'm not sure if he is still running the 7in)
Old 12-03-2010, 06:32 PM
  #92
Jamie@FastFord
Jamie @ Fast Ford
Thats a great idea, only problem is it would be a real pain to test. The biggest issue is that diffs are like handling packages, and personal preference plays a massive part in which would best suit you and your driving style.
Old 12-03-2010, 08:17 PM
  #93
Touring Car Spares
the 7" version is a Caterham diff ! Ive had a 7.5" diff with them ready to build a prototype into for 8 months , when i last spoke to titan they promised "again" that they would make these but i suspect theyre only beefed up kit car diffs .
If theyre finally making proper 7.5" units then i'll be very interested to try them out in a racecar ,see if they will be any good to sell !
Old 12-03-2010, 08:33 PM
  #94
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
You carnt find a thing on the net about titan diffs other than if u have a 4x4 nissan lol other than one bit were they talk about a atlas and a 7inch ford diff it also claims to give better traction than a steel plated diff also says noise will be reduced! Is anyone running one right now! will be good too see if they are better than grippers as grippers are very good diffs and give me really good traction and thats with around 500lb ft.
Old 12-03-2010, 08:36 PM
  #95
Fudgey
Baby Cheesus
Fudgey's Avatar
so can you rebuild the cossie 7" diff yourself? or have you chopped it up etc to get that pic?
and how do you 'tighten' them?
Old 12-03-2010, 08:40 PM
  #96
markk
markk's Avatar
how many planet ears does the titan diff have then?
Old 12-03-2010, 08:44 PM
  #97
Fudgey
Baby Cheesus
Fudgey's Avatar
says 4 on their website markk
Old 12-03-2010, 08:47 PM
  #98
ajamesc
ajamesc's Avatar
ive found them now under titan motersport
Old 15-03-2010, 09:42 AM
  #99
Mike1
Mike1's Avatar
Cheers Jamie - I appreciate what you're saying esp about the personal preference. For me, on a road car, the Gripper type seem far too clunky and noisy to put up with although I appreciate for just trackday/loose surface use they seem the best option.
The Titan one sounds much nicerquieter/more refined but I'd be reluctant to fork out over £1000 to find it wasn't quite what I wanted.
It would just be fast road use for me
Old 15-03-2010, 12:32 PM
  #100
Jamie@FastFord
Jamie @ Fast Ford
If it's just fast road use you want, there's nothing really wrong with the standard viscous diff. You can get them re-rated (using different viscousity fluids) to make them behave slightly differently (the last one I had done by Bernie at CTS was spec'd for 'hooning around'! lol)
The biggest problem with the standard diff is the planet gears are notoriously weak. As the are based on an open diff with a viscous coupling effectively attached to one end, they still retain two sun and two planet gears. It is these that get munched in big power cars and when people launch the car. Motorsport planet gears are available but even these have their limits, and I personally wouldn't want to run one with much over 400-450 bhp, because my dickhead-like driving style would mean I'd break it frequently.
The plated-type diff like the Gripper and Titan TTM have a 4-planet gear design, so can deal with increased torque loads. This makes them ideal for motorsport applications, but they can be a bit harsh and noisey for road use. The plated diff itself is actually very strong, but the weakest link now becomes the standard crown wheel and pinion. That's why the big boys run 9in rear diffs.
Old 15-03-2010, 01:33 PM
  #101
dan_boy
dan_boy's Avatar
Yes - it's the dog's danglies . Sufficiently so that I am outing the Quaife ATB for one .
Mike,
are you all for the Titan diff because of its build quality alone, or its actual working properties?
Was going to get a Gripper myself but interested to hear why you prefer it so much.
Dan
Old 15-03-2010, 03:07 PM
  #102
Mike Rainbird
Caraholic
Originally Posted by dan_boy
Mike,
Dan
Three reasons .
Build quality, working properties and lower noise . You also have a choice of locking abilities, which allows you to chose whether it acts as a two way or one way diff.
Old 15-03-2010, 07:24 PM
  #103
Mike1
Mike1's Avatar
Cheers Jamie, point noted about the re-rated VCs.
Seems like quite a few of the big power cars runs the 9" rear end with a VC and a cooler, heat build-up promoting inconsistent behaviour seems the worst bugbear of the VC
Old 31-03-2010, 05:47 PM
  #104
Mike1
Mike1's Avatar
As per the above, the article is in Fast Ford this month on pages 130-136
Total cost for parts new and fitted by CTS comes out at £1390.
Will look forward to the driving reports
Good work Fast Ford
09-10-2015 07:38 PM
FlashRS
13
31-08-2015 06:02 PM
14-08-2015 07:29 AM
Old ford
31-07-2015 06:50 AM
Quick Reply: best diff for 2wd cosworth
