are these fuel pumps any good for 350-400bhp yb????
i have 2 of these fuel pumps i was planning on running on my 350-400bhp yb cosworth project.
are they man enough?
SPECS:
EXTERNAL FUEL PUMP
150 LPH @ 5BAR
INLET CONNECTION 15mm(1/2)
OUTLET CONNECTION M12X1.5
LENGTH: 200 mm
DIAMETER: 42 mm or 60 mm (with rubber sleeve)
MAX POWER/Cons(Amps): 10
SPECS:
EXTERNAL FUEL PUMP
150 LPH @ 5BAR
LENGTH: 200 mm
Yes more than enough, the two combined are more L/min than a group a 044 pump.
044 flows just under 4L minute at 5 bar and 12 amps, so x by 60(minutes in hour) = 240, or just a bit under, probably nearer 230 L hour.
Hope this helps,
Hope this helps,
Saw one of these micky mouse regs a few weeks back on the rollers, on a n/a engine went from 2- 6 bar after setting at 3!!, crap even for £20, bloke was a tight arse git!!
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
