what goes where :? with pic
09-01-2005 | 12:12 PM
and the bit on the top too (2 metal plug thingys)
09-01-2005 | 12:14 PM
1 goes to airbox
2 goes to actuator
3 goes to compressor
i think - i'm probably wrong
09-01-2005 | 12:19 PM
If you look on the valve at the end of the pipes it says
'W' = Wastegate.
'C' = compressor
'A' i think it says A = Airbox/Atmosphere.
09-01-2005 | 12:23 PM
Quote:
'W' = Wastegate.
'C' = compressor
it says "R" , "C" and "W" , whats the R??
09-01-2005 | 12:25 PM
R = Return - return to airbox
09-01-2005 | 12:39 PM
Quote:
There you go.As long as you got wastegate and compressor right it will be fine anyway.
09-01-2005 | 06:55 PM
what about the 2 metal things on the top, sorry i didnt mark then
09-01-2005 | 06:57 PM
Thats for the electrical plug that should be connected to it
09-01-2005 | 07:01 PM
You might ba able to see it (just)
09-01-2005 | 07:08 PM
09-01-2005 | 07:14 PM
Quote:
totally pointless bit of braidied pipe work
radders as they said, r is returb toi air box ( think its needed on a erst as it may go top the metering head ) the rest as stated, oh ant they need jets too but thats a pros job, use rob@scc for the set up on it mate
09-01-2005 | 07:24 PM
i wont be having a metering head when it fitted
09-01-2005 | 07:26 PM
Quote:
then loose the amal valve and get a proper boost controller !!!!!
jameswrx
Modellers Corner.
17
09-10-2015 08:26 PM
07-10-2015 12:56 PM
griffo69
04-10-2015 11:58 AM
locum8
01-10-2015 01:50 PM
