question regarding lower arm to sub frame pinch bolts (mot tester question)
burnzy
as above, now my car passed it's mot
but he did say he could of failed it cos the pinch bolt between the subframe and lower arm was upside down.
as you might know that it was the bolt that catches on the gearbox resulting in dropping the subframe to remove it in one piece, i just cut the head off and put a new one in upside down, now i can see the logic in that "if" the nut was to loosen the the bolt wouldn't fall out but it's a nylock and the chances are very slim if any that it's possible to happen, is what he was telling me the truth i chose to believe him and keep my pass anyway
it just seems pointless as it's nylocked and a simple solution for a pain in the arse problem.
burnzy
burnzy
Believe you me, this is not in the guide
burnzy
Many years ago after a rebuild on an S2, the tester tried to fail it because it didnt have the retaining tabs around the steering rack to bulkhead bolts. The Mk4 was never fitted with them, only the Mk3 but it took some persuading.
Adam Graham
06-09-2015 06:04 AM
