Cosworth steering rack
Right Folks
My 106 cosworth before its strip down ran full 4x4 cosworth setup, ive decided to change the original cosworth power steering setup it ran to using a Corsa C EPS unit/coluum,
Question is what non power steering rack can i use with the new EPS system that is a direct replacement to what it originally ran? was there a sierra rack that didnt have the power steering, or can i just blank the original fluid ports on the cosworth item?
Maybee Mr Gallacher could shed some light as the Focos uses the same Coluum?
Secondly Hopefully Martoon can post a pic? the 106 bottom arms arnt like any other cosworth item they seem to bend at the point where it joins to the front engine cradle, Martoon is also puzzled from what they are off, they look factory ford and dont seem to be modified or shortened in any way, i want to fit adjustable items.
JK12
33
26-04-2021 12:09 PM
borboyous
22-08-2015 11:17 AM
