help required fitting AP six pots
Whats the gap supposed to be between the mounting bell and the actual pads when first fitted, as trying to fit at the moment and they are JUST touching on the outside edges of the pads,is this normal?
or have I somehow fitted them incorrectly?
cheers
Mat
cheers
Mat
does anybody have any suggestions as to why only the edges are JUST touching,the middle of the pads isnt,its like the shape of the pad and bell are slightly different,imagine putting a small circle inside a big one with the edges meeting at the top (if that helps
please any more suggestions
Mat
Mat
Mat, if they are only just touching as in a fraction of a millimetre, i wouldn't worry about it as they will bed in to the shape of the disc................I'm sure someone will correct me if i'm wrong
thats what it seems like, but I didn't want to start using washers if they are not sposed to be there?
I bought them new from Martin at Reyland so I am sure all bits provided are correct?
Mat
Mat
they seem to be exactly the same,
I've tried swapping them over and changing over calaipers but still the same,I am thinking possibly when the wheel goes back on and everything is done up properly tight that it may pull them back,its such a small bit touching
it is doing my head in
Mat
Mat
brom,dont mean to be cheeky
but any ideas what I could be doing wrong mate?
in your experience are the pads VERY close to the mounting bell at the outer pad edges?
thanks
Mat
thanks
Mat
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
borboyous
Aug 22, 2015 11:17 AM
,dont worry I wont bodge them
