Removing Long Studs?
Hi all,
Im trying to get the 6 long studs out of my 200 block Yb. I have tried locking two nuts together and tried un-doing them but they are barstad tight!
Is this the best way of doing it? Anyone got any tips?
I have however employed some muscle for later on this evening so he maybe able to get them undone by locking nuts together lol
if the nuts are still spinning without turning the stud , try adding a few extra nuts so to say
so insted of using 2 nuts to lock together ,use 3 nuts and wang em up against each other !!
failing that then would weld nut to it then remove ...unfortunately this will knacker your long studs
was gonna say use a long bar and socket to do up the top nut rather than using a normal rachet/spanner then use a long bar to get it off!!
Found when i was fitting them had to be really really really tight too or the nuts moved!!!
grishenko45
09-09-2015 12:58 PM
