ford transit issues
Old Feb 20, 2010 | 08:22 AM
coswurv's Avatar
coswurv
Default ford transit issues
Ive got a ford transit swb 2ltr turbo on an 03 plate, ive had issues with it in the past losing power and the glow light flashing, that seemed to go away after a few miles so i put it down to a dirty connection. I went out this morning and started it up to find the accelerator pedal not working at first? plus it doesnt rev straight away seems a bit lethargic, yesterday it seem'd to have no go then woop it would shoot off (as much as a diesel turbo can) felt like really bad turbo lag, anyone had any issues similar etc or know what i could try ?
Old Feb 20, 2010 | 08:30 AM
james kiely's Avatar
james kiely
my own transit does the same and i was talking to a mate of mine the other day and his two transits done the same it seems to be a common problem and all seems to head to the accerator which is electric ,i havent fixed mine yet but its not a big job to rectify,so ive been told .
cheers james
Old Feb 20, 2010 | 08:38 AM
Miller 3's Avatar
Miller 3
try cleaning the EGR valve Paul, if that doesn't work change the throttle pedal.
Old Feb 20, 2010 | 08:40 AM
james kiely
where is the egr valve mate ?
cheers james
Old Feb 20, 2010 | 08:48 AM
Miller 3's Avatar
Miller 3
at the end of the top boot hose
Old Feb 20, 2010 | 09:15 AM
boothy's Avatar
boothy
Get your self on here http://fordtransit.org/
Old Feb 20, 2010 | 09:32 AM
coswurv's Avatar
coswurv
cheers for the info guys, Doug ill try that next week and yes mate ill have a good look on that forum.
Old Feb 24, 2010 | 01:21 PM
MrMPuk's Avatar
MrMPuk
You could change parts all day long and not solve it, first thing you need to do is read the fault codes and find out what the fault is.
Old Feb 24, 2010 | 03:40 PM
coswurv's Avatar
coswurv
The problem with mine was found without the code reader in the end. Mine went back under warranty a few years ago and they replaced the top rubber hose from turbo to air box. Basically it had trapped a wire under it, resulting in it rubbing through, the wire sits near the turbo and is inside some tubular insulation stuff and it feeds a plug clipped to the side of the head i just stumbled across it through luck really, pulled the wire out the way and all has been fine.
borboyous
Aug 22, 2015 11:17 AM
Bailes1992
Aug 16, 2015 07:14 PM
Mark RS
14
Aug 11, 2015 11:45 AM
Fil
14
Aug 10, 2015 07:42 PM
