amplifier help
Old Feb 17, 2010 | 04:23 PM
focass's Avatar
focass
focass
Default amplifier help
can i run my 6x9s and a single subwoofer off a 4 channel amp
does it matter that theres a channel not being used?
Old Feb 17, 2010 | 04:46 PM
BigChuck's Avatar
BigChuck
it depends on the amp, you should be able to use two channels for the 6x9's and bridge the other two for the sub (check the amp hand book before doing this,it could end badly if you don't do it right)
Old Feb 17, 2010 | 04:48 PM
cossiejsy's Avatar
cossiejsy
I would run one amp for the 6x9 and get another one for the sub
Old Feb 17, 2010 | 05:05 PM
focass's Avatar
focass
focass
ok
Old Feb 17, 2010 | 05:06 PM
focass's Avatar
focass
focass
i will be getting it fitted so this should be ok?
Old Feb 17, 2010 | 05:09 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
It wont matter not running 1 channel mate, as said use bridge chanells. something like chanel 2 for 1 6x9 chanel 3 for the other then positive off chanel 1 and negative from chanel 4. wil get nore power to your sub then, or if using a seperate amp get a monoblock amp for sube and either bridge the 6x9s or run in series
Old Feb 17, 2010 | 05:12 PM
Oranoco's Avatar
Oranoco
I would run the 6x9's off the headunit, and use the 4 channel amp to run front speakers and a sub as mentioned above by bridging 2 channels to give a single more powerfull channel for the sub (amp dependent as to this being possible). 6x9's aren't the best solution and amping them without doing anything to the fronts will give you noise but not a nice sound
Old Feb 17, 2010 | 05:51 PM
WongRS's Avatar
WongRS
This mans got it!
Sound from the back sounds nasty, get a decentish set of fronts and amp them leave the 6x9's for rear fill (if you have to have them) and it'll sound alot better.
Bailes1992
Sep 3, 2015 02:17 PM
robbieg
16
Aug 18, 2006 04:50 PM
IMOL
Ford Escort RS Cosworth
Dec 6, 2005 07:01 AM
intruder
Apr 23, 2005 10:05 AM
foreigneRS
Dec 20, 2004 01:15 PM
