melted fues but not blown
Old 12-02-2010, 06:24 PM
dom_xr3i
why poke the animal
dom_xr3i's Avatar
Default melted fues but not blown
i've got an escort gti and the fuses for the heater and also the fog lights keep melting but i dont have the fog lights on the car anymore cos i have changed the front bumper but the heater fuse only lasts a week before it melts
anyone have any ideas wot the problem could be? my father in law thinks the heater motor could be nakered cos it only works on the highest setting
please help thank you
cheers dom
Old 12-02-2010, 06:47 PM
stickertone
stickertone's Avatar
it could be drawing a high current due to the motor being screwed, this would also account for the motor ony working on high setting, check the amount of amperage the motor is drawing, i think you'll find its more than normal.. hence the fuse melting
Old 12-02-2010, 08:43 PM
rich123
rich123's Avatar
i had this its the plastic thats the problem cheap crap plastic i put some original fuses out of a ford and i have no problems anymore,sounds stupid but try it
Old 12-02-2010, 08:53 PM
botters
competant bodger
botters's Avatar
mine kept melting fuses so i just ran a wire from the live on the battery to the heater motor! fire hazard i know but works well just a pain in the ass having to open bonnet to disconnect it!
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
i had my fuse box melt a bit back due to rad fan being seized and didn't blow fuse, but melted the fuse box and plastic on the fuse.
try a smaller rating of fuse and or sort the fan out.
p.s. i know it's the demister fan in your case, but same applies.
Old 12-02-2010, 09:22 PM
RichieST
RichieST's Avatar
Normally fuses melt due to a poor connection between fuse/holder, or a poor solder joint on the fuse holder. This would cause a heat build up. It wouldn't be drawing any more current as usual so the fuse wouldn't blow, but the poor connection would cause heat to build up, thus melting the fuse plastic. Have seen it a couple of times on audio installs, cleaned up the fuse holder and resoldered the holder properly, and problem solved.
Old 13-02-2010, 11:02 AM
dom_xr3i
why poke the animal
dom_xr3i's Avatar
cheers for the help
it requires a 25amp fuse but it pops straight away so i put a 30amp fuse in and it just melts i'll try some ford fuses
but what gets me is the fog light fuses melted but i dont have fog lights connected anyore since changing my front bumper to a wrc replica
Old 13-02-2010, 11:37 AM
Heat is naturally produced whenever there is a flow of electrons or ions through EVERYTHING apart from superconductors.
The positive charge carriers are immobile in a car circuit(dc) and only the negatively charged electrons flow, using a rogowski meter will show a electric field is produced also.
It is of course true that the higher the resistance be it load or bad connection will result in more heat produced.
A much more famous problem on vaux's with melting RHS fuses/fusebox area, same thing as happened to cossie with the fan loom.
In short any fuse seeing a load from whatever source will produce heat, so something is still connected and drawing from that circuit
Sierrasideways
15
31-08-2015 10:10 AM
JoeyBoyden
20
22-08-2015 03:23 PM
Quick Reply: melted fues but not blown
