**HELP** Head Gasket (Self Replacement)
![Question](https://passionford.com/forum/images/icons/icon5.gif)
Hey guys thanks for making me welcome here on passionford....
I have had loads of quotes as you prob know its going to cost me around the £500 mark to fix my head gasket. SO i have decided that im going to try takle this on my own..
Im just wondering if anyone has tryed this before and or if anyone has a online haynes manual that is available??
All ideas as brains welcome...
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
http://www.linktobusiness.co.uk/foru...16&t=144&p=863
- How to change the Valve Stem Seals
- How to Remove and refit camshafts in the zetec engine
- How to fit a new Head Gasket
- How to re-time the zetec engine (crank to cams)
All in one guide :d
All in one guide :d
Gary Krishna
There will be a haynes manual for an Escort. ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
The Zetec engines are a doddle to work on really if you've got a bit of mechanical knowledge and the right tools.
If you're not mechanically minded, it may be worth getting you're garage to do it. If you really want to have a crack at it, fair play, it's the best way to learn. Just take your time and follow the manual to the letter and you should be fine!
![](https://passionford.com/forum/images/smilies/roi.gif)
All in one guide :d
All in one guide :d
Thanks for this seams to be everything i need will keep you all posted then il post some pics of my Princes on here!!
![ban-split](https://passionford.com/forum/images/smilies/ban-split.gif)
