compression ratio/compression test
Old Jan 19, 2010 | 05:50 PM
dake205's Avatar
dake205
Default compression ratio/compression test
just wondering does compression ratio effect results on a compression test, i had never heard about compression ratios before i got my cosworth, also what figures do you usually see on a bt yb, tested mine today and got 150 across all 4 cylinders.
Old Jan 19, 2010 | 06:02 PM
Yes CR does affect compression pressure, 150 on all 4 is ok.
Old Jan 19, 2010 | 06:33 PM
frs2208's Avatar
frs2208
Your allowed a tolerance of 10% over the piston's..... Had mine tested few weeks ago as was burning oil, 165% across 1,3 and 4, 45% on number 2.....
TPM961
Jan 15, 2018 10:50 AM
Prickly_buzz
Dec 7, 2017 09:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
