BDG engine on carbs, who makes it? which is the best?
Dear All,
I'm from Italy and I'm willing to buy a BDG on carbs for my Ford Escort Mk2 Gr4, FIA650, rally car.
There are many company in UK that sell and produce the BDG but.....which is the best? Who makes the best BDG in England?
Thanks
Thanks
Geoff richardson racing engines http://www.geoffrichardsonengines.com/
Been using them for many years won many championships with us
he remakes nearly all the parts now including metering units if you did ever go MFI
Thank you guys, do you know how is Wilcox?
Also, in rally UK, is most common to see BDG on carbs or mechanical fuel injection?
There are many people/companies very caperable of building or supplying a BDG parts available from many sources including KAM developments, Burtons, Richardsons etc.
Depends on budget and if you want carburetors or mechanical injection.
A new engine on carbs Ł20,000-Ł22,000 or injection Ł24,000-Ł26,000.
Steve
Steve
PS your escort needs a BDG or BDT,(if you are going to use a YB the G60 gearbox will not be strong enough but a G69 will)
Hi Steve, thanks.
My escort, since is following FIA rules, needs a BDG.
If I have to define "best" I will say "reliable, powerfull" for the engine and "service" for the company who is building it.
C.R.E.A.M.
well if your going down the who builds the best, who built the best works escort engine ???.
http://www.racecar.co.uk/terryhoyle/engines.html
which engine won the wrc in a mk2 escort ???
Try the companies mentioned, also Jondel, DTW, TMR, JRE, SWRE, Field Motorsport, Paul Fisher, there is loads your have to make your decision.
Steve
DTW also built engines for the works escorts.
Steve
C.R.E.A.M.
yeh and Hoyle will still build a works spec bd if asked and you can afford it,seems matey wants the fookin best so call the bloke who does ferraris and bd's,after all rothmans paid for and david sutton prepared and ari vatanen drove a Hoyle prepared BD,suppose they can talk italian to each other too lol.
Good Luck.
Steve
Wilsfoci
15
30-03-2016 10:26 PM
borboyous
22-08-2015 11:17 AM
track.focus'd
12-08-2015 05:53 PM
