max power on t35
max power on t35
as above really on a cossie engine,ive got an rs 5oo size intercooler,bd10 cams,standard bottom end just bored out slightly to .5,4x4 inlet,will buy a 2wd exhaust housing,havnt got injectors or chip yet
ok cheers,its all going in my mk4 escort estate so wont need a massive spike of power anyway really cause of the weight,i will keep an eye out for some standard cams then once i try and get rid of my bd10s
If you,re only going for 350 bhp then i,d go!!!!!!
I,d say the turbo will max out around 370-380 bhp, as for injectors, you could go Greys or Siemens 55lb seem to be favourable at the min..
I had a T34.48 on my 3dr 3yrs ago with Greys, Live NMS map, 500 cooler peaking @ 32psi and it made 360bhp with similar torqu and it was a lovely road car..
There,s some on here that reckon they,ve got 390 on a T34.48, i don,t reply to them....
oh right ok then i will sort out buying the turbo then,i did think the .55 would be better but wasnt sure if it would make to much difference at the power im aiming for
Sponsor
Jones,
you never get those valuable minutes back do you chap
Jones,
They say the Spray pattern is better, again, can,t pass comment as i,ve never used Siemens, Greys were good for me and my mapper...
If i were thinking of changing my Injectors then i think i,d give the Siemens ago, mailny out of curiostiy tbh..
But we know what that did to the cat..
1 Post
to be fair base it on the figures below, (subject to rollin road)
Real world figures on standard cams and head
.48 340ish BHP
.55 360-370ish
.68 380-390ish
As for injectors, i believe Siemens have a beter spray pattern, 120 as opposed to 90 from memory
Been out ford scene for a while though
.48 340ish BHP
.55 360-370ish
.68 380-390ish
SMILER258
28-09-2015 09:04 AM
