Millers 10W 60 Racing
Depends on Engine though. Karl specs his Big Boost CVH's with large bearing clearances, as does my local race engine builder. The boost tries to squeeze the oil out of the bearings.
Originally Posted by Rick
Well, shouldnt it be thinner than a 15 50 when cold, just not thin up as much when hot? Ive got some u see, might try it.
W = winter ie when the oil is cold
so 60 is thicker than 50
besides all that, why do you want racing oil in a road car?
alex
Yes im sure. If it's a 60, it wont thin up as much as a 50 does when hot.
Mobil 15 50 is a motorsport oil, and plenty of people use that..... Modern road oils are too thin for older engine designs.
no thats not somthign you can tell...
there are three viscosity points oil is measured at... Winter (cold), hot and very very hot... the 1st two are the 20w50 people refer to, the other is not listed in the same way. But it does get listed in a round about way on the back in terms of the specs...
Alex
Alex
Lol, here we go
a 10W 40 oil is thin on startup to get to the parts it's needed quickly, and gives the protection of a 40 when hot.
Oil always thins when it's temperature is increased, ie it's viscostity decreases. A multigrade oil is one which the rate at which it thins at is reduced. Going back to 10W 40, this oil has a base weight of 10, so it when cold it acts as a 10. However, when it is hot, it does not thin as much as a normal 10 weight would. It actually has the same viscostity as a straight 40 would when hot. But, a straight 40 is still thinner when hot, than a 10 is when cold.... The bigger the difference between the two numbers, the less responsive the oil is to a change of temperature.
In my opinion sae 60 is too thick. Use sae 50 at most. A decent 10w-50 synthetic is a good bet or a fully synthetic 10w-40 or 5w-40.
60 can cause problems through oil drag and extra heat build up due to the thickness causing added friction.
I would not recommend it as a grade for modern cars.
Simon
Simon
Norris Motorsport
Oil man,
I think you'll find that being based on a pinto makes the YB vintage since the pinto engine originated in the early 70's. The recommended oil viscosity for this engine in europe is 20w50.
Alex, if what u were saying is right, then an oil would thicken when hot..
It doesn't make the recommendation of higher viscosity fully synthetics wrong.
The fact is they are far more available and affordable these days and are superior lubricants in any car 60's onwards.
Remember a 10w-50 is the same thickness when hot as a 20w-50, it just gives more instant cold start protection.
Simon
Simon
cant the use of synthetic oils in CVH's cause glazing of the bores.. ive read that before on here im sure it was Karl that said it. hence why i use a mineral oil..
Well, just put some in, so will watch the temp and pressure gauges to see what's going on. I can get hold of some Valvoline 5W 50, which sounds nice, just wondering if it's a tad too thin for the CVH.
i dont bloody know.. IM SURE it was Karl that stated that the use use of synthetic oils in RST or the like is not recomended.. i will try and find the post.. sorry in advance if im wrong by the way!
Oh no my favorite subject!
Two words spring to mind, wives and tales. Apologies to anyone I offend.
There was a problem in the 80's with Diesel engines known as bore polishing and it is well documented but I personally have never seen an engine that has been rum on synthetic oils that has experienced bore glazing.
Yes it is true that running in a new or re-bored engine on synthetics will slow down the process (it will not damage the engine) so mineral oils are preferable during this period but this whole issue is a mystery to me. Has anyone got any pics of bore glazing that they could email me?
I would love to see some and pass them by a major oil company for comment.
Simon
Simon
The Youth.
30-09-2015 09:59 PM
