What have you used to replaced your old fuel pipes???
Need to replace the fuel pipes on the white saph, don't really want to go to the expense of aeroquipping like i did on my other saph.
What have other people used, there must be a similar type of pipe off the shelf to what's already on the car.
Pics sugestions welcome.
as above.. .microbore (i think that's the name) copper plumbing pipe.. 8mm.
paul hills should be able to hook you up.
All copper lines are not created equal. "They Say" not to use pure copper lines in automotive applications because they can become brittle. Brittle leads to cracks, leads to leaks, leads to fires, which are considered A Bad Thing. CuNiFer is an alloy of Copper, Nickle and Iron.
"Cunifer is seamless, copper nickel alloy DOT approved brake line used for OEM and replacement brake lines, fuel lines, power steering and cooling lines."
copper for heating iv never know it getin brittle in a house
Pure copper also catalyzes the auto-oxidation of fuel, the mechanism of sludge formation. Pure copper should never be in contact with fuel. This catalyzing also makes the copper brittle. I am sure though that this takes years.
This is only what I have heard/read - never experienced but there is a lot of info out there on this!
[QUOTE=rog;4651739]Sound, thats given me a few ideas, I'll sort that out asap.
Bob, nae fancy a decent car for cheap???
how cheap? really shouldnt once you go jap you dont go back lol
It's KUNIFER 10, and as said copper is unsuitable if subjected to any degree of vibration.
I use OPA, oil petrol air pipe, resistant to all fuels/oils to 25BAR, around Ł1 a foot, I use 8mm for the cossie and most other stuff, 7.6mm hard to come by.
Ok cheers, next question, have you eliminated all the old fuel lines or have you joined new fuel line onto the existing standard one that's joined onto the rail and the black heatshrunk pipes at the back???
How have you done this, just using jubilee clips or what???
I get mine from Walker Rubber and Plastic, 01603 415044.
Any half decent flexi pipe suppliers, or fuel pipe suppliers should have this, I heard some issues of OPA cracking prematurely on friday, after about 1 year, must admit I have some much older than this 5-6 years and is still perfect.
i think your getting mixed up what your after is cupronickel http://www.google.co.uk/url?q=http:/...-kK7egPhwZ0dnA
cunifer is a totally different metal used on ships
cossie09
14-09-2015 04:21 PM
