paul johnstons mental zetec turbo (graph and pics)
Old 14-01-2010 | 06:58 PM
  #121
scoooby slayer's Avatar
scoooby slayer
i have to say i would be worried about below 3 bar oil pressure at 7500 rpm.
not a dig in the slightest thats insane power for a zetec its certainly gonna make alot of yb powered cars look silly
why does the oil pressure drop off like that ?
is it a zetec trait ?
Old 14-01-2010 | 07:02 PM
  #122
Lamb Souvla's Avatar
Lamb Souvla
Originally Posted by Porkie
I KNOW its alot more expensive and not as much fun etc etc etc.... and its not the point.
but check this out.... IN THE WET!!!! boggo standard 911. frightening level of performance available to even no talent joe public now!
http://www.evo.co.uk/videos/planetev...911_turbo.html
Chris Harris is such a legend.
Old 14-01-2010 | 07:53 PM
  #123
crazycage's Avatar
crazycage
Originally Posted by zetaboostboy522bhp
in reply to your question , no i aint changed my mind as i wouldnt want the risk , even if very slight risk be it for the sake of Ł200.
and soz mate but i certainly dont have any prob with what you have done or achieved with your car. infact i wish you all the best . you have your opinions and i have mine , lets leave it there!!!!
cheers paul
thats fair enough mate it was a genuine question that i only really asked as ian's your tunner too and he spec'd and built it with the standard mains and to tbh if it was my engine at that power i to would buy them and a dry sump just to be on the safe side, but i dont think i would upto 500hp but ive said that from the start ,but the oil pumps well we all know they can be killers at high revs .
Old 14-01-2010 | 10:01 PM
  #124
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
like i said mate i personally think that if youve spent Ł7500 + then its daft not to spend money on any weak link in a engine, as for ian specing the engine , ian speced that engine for 460bhp like mine lol, pauls engine now has more than 120 bhp more than ian built it for , for his own car before ian sold it to paul , so i guess ian would say if it aint broke dont fix it ,but i couldnt afford to rebuild because of a shit part like a oil pump /mains caps etc giving up the ghost. i surpose its like my engine when it was on the dyno ,i would of never reved it past 7000rpm if i knew about the oil pump situation back then , as ian said sunny run upto 8250rpm at brunters and had no probs , maybe i was the lucky one? its a sad case really when a Ł70 part is causing so much trouble. there must be a solution to the problem!!!
cheers paul
Old 14-01-2010 | 10:21 PM
  #125
scoooby slayer
if it was mine i wouldnt be hammering it until the pressure drop is resolved. ive never seen pressure drop off like that on any engine ive owned.
Old 14-01-2010 | 10:28 PM
  #126
nigel b's Avatar
nigel b
Originally Posted by Luca
My set up is different to Szaybks we will just have to see what happens on the engine dyno
did you get your rings specced for dry sump use?
Old 14-01-2010 | 10:38 PM
  #127
bigchez's Avatar
bigchez
He may well be acting cool but the eyes give away just how hard that is accelerating
Old 14-01-2010 | 10:45 PM
  #128
J1mbo's Avatar
J1mbo
B1mbo
do you really think we would send out a engine with poor oil pressure
on the engine dyno sheet, the oil pressure gauge takes a long time to rise and settle,
when on the dyno, pull, correct fuelling, lift,
pull, pause, record data, lift
in that short time the computer dosnt recognise the oil pressure rise
HENCE having a 10inch manual gauge taking pressure straight off a oil pressure take off from the block
dont try to teach your grandma to suck eggs
Old 14-01-2010 | 10:51 PM
  #129
Luca's Avatar
Luca
Lukesville
BUT the question is why would I need different rings???
Old 14-01-2010 | 11:03 PM
  #130
nigel b's Avatar
nigel b
crankcase pressure and blow by
Old 14-01-2010 | 11:13 PM
  #131
J1mbo's Avatar
J1mbo
B1mbo
what is the difference between a "normal ring" and a "dry sump ring" then ??
Old 14-01-2010 | 11:14 PM
  #132
rst-g's Avatar
rst-g
ZETEC TURBO
isn't that what a good breather system is for ????
Old 14-01-2010 | 11:18 PM
  #133
TimC's Avatar
TimC
But then comes the queery of whether you should run a breather system with a dry sump system due to the pump and the vacum required for it to operate as best as poss...... (I could be wrong)
Old 15-01-2010 | 07:47 AM
  #134
scoooby slayer
why does it recognise it in lower revs then ? you can be as sarky as you want mate but it sounds abit fairy tale tbh ? looks like the pump cant keep up with the demand for oil.
what did the manual gauge indicate at 7500 rpm then ?
im in no way questioning your dad and his company, russell saywell is a good friend of my family and he used your dad for his cossies and has always spoke very highly of him.
i just cant get my head around the pressure drop off ? it would worry me.
Old 15-01-2010 | 09:27 AM
  #135
paulj's Avatar
paulj
tbh after speaking to harvey,i`m in no way bothered about that.
after all it would`nt look good on scs,to send it out with low oil pressure
would it,
cheers paul
Old 15-01-2010 | 09:45 AM
  #136
AustenW's Avatar
AustenW
Paul J
Did they do a power run after mapping? Is there a plot?
I'd be interested to see how the turbo spooled up on your engine
I take it your running a GT35 with .8 ex housing?
Austen
Old 15-01-2010 | 10:41 AM
  #137
sas's Avatar
sas
should be good!
A dry sump set up runs negative pressure in the sump, you just need a oil/air seperator on the top of the catch tank for breathing.
Simon.
Old 15-01-2010 | 11:08 AM
  #138
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
would it,
cheers paul
Congrats Paul good to see ya back, should raise the bar by the looks of it. Dont worry about the comments, every Tom, Dick & Harry will have built an engine more Powerfull & better built its par for the experts that abound on here, hit them where it hurts in the record book .
Old 15-01-2010 | 11:42 AM
  #139
LINCOLN's Avatar
LINCOLN
Originally Posted by AustenW
What you failed to realise is that the titan system was developed for "formula ford"
Formula Ford are single seaters that run a Zetec 1800cc nasp motor with about 150bhp
This is a completely different application
The pump is the heart of a dry sump system
You have to consider the fact that the 2.0 block has oil squirters and an oil take off for the turbo on the preasure side. Also need to consider bearing clearances for oil preasure drop too.
Then you also need to consider the scavenge effecct of the pump as the oil requirements and blow by past the rings is completely different in Pauls 570bhp motor to a virtually standard 1800cc formula ford engine running 150bhp
Go with Pace all day long even though they are a bit slow
The design spec sheet they will send you for the pump is very important to get right
The recent article in racecar engineering highlighted the issues with getting it right first time.
Just my 2 pence worth
Some good points.
However having personally seen the quality of both Pace and Titan dry sump sumps the Titan wins hands down with the Pace one looking like it was cast from old coke cans by comparison.
However on the pump side, I was a little taken back that the Titan guy suggested feeding the turbo oil from the scavenge pumps!
The same Racecar Engineering article highlighted that the Yanks are most obsessive about crankcase vacuum - so why not a yank pump? Given that most Yank pumps will flow double (at 57% crank) what a Yb needs (3gpm) you could easily underdrive such a pump! Make sure though that you get either a external pressure bypass or a pump that bypasses into the scavenge side so not to heat the oil.
Old 15-01-2010 | 11:44 AM
  #140
LINCOLN's Avatar
LINCOLN
Sorry, congrats on the motor!
Old 15-01-2010 | 11:53 AM
  #141
LINCOLN's Avatar
LINCOLN
Simon.
You do need an oil air seperator on top of your dry sump tank. You also mostly seal your engine but must have flow from the the top of your motor to allow the flow of oil/air to your sump/dry sump pump. Ever tried to suck on a milk carton? No flow huh! Some people suggest a open line from your head to the tank but I think better a vag reg in your rocker cover to allow flow of oil from head to pump and a flapper valve from PCV area so you do not blow seals out when lifting off throttle/positive pressure in crankcase.
Old 15-01-2010 | 11:55 AM
  #142
Luca's Avatar
Luca
Lukesville
Originally Posted by LINCOLN
Some good points.
Lincoln Im guessing you got yours through Rainbird as he was enquiring around the same time as me. Is yours all running now?
Old 15-01-2010 | 12:03 PM
  #143
LINCOLN's Avatar
LINCOLN
Yes through Rainbird - engine is together now but not started. Good mate has same setup (titan sump/peterson pump) running in car - very good vacuum through rev range. I have got sump vac sensor so will log when I run.
Old 15-01-2010 | 01:08 PM
  #144
rst van's Avatar
rst van
is that ian howells old focus in the first pic??
Old 15-01-2010 | 01:09 PM
  #145
paulj's Avatar
paulj
lmfaothats what i intend to try and do rod
cheers paul
Old 15-01-2010 | 06:18 PM
  #146
scoooby slayer
http://www.fiestaturbo.com/forums/57...orth-vt133978/
ive found this very similar bhp engine but yb, little way down print out of on your dads dyno with steady oil pressure ?
i got the printout separate now yb here steady oil pressure :
the thread engine dyno prointout here :
if its the dyno cant see the pressure quick enough why could it on the yb ?
im a mechanic myself on caterpillar engines and i cant understand why it would do it ?
Old 15-01-2010 | 07:43 PM
  #147
J1mbo's Avatar
J1mbo
B1mbo
right, your welcome to come down tomorrow and see for yourself how the dyno reacts, if you decline i will take pictures .5 of a second apart of the manual gauge reading full pressure and the dyno one rising, would that be good enough for you ?
also, dave jackson jacko996 will be here watching his engine im sure if he sees this thread he will comment
jim
Old 15-01-2010 | 07:52 PM
  #148
scoooby slayer
jim
right, dont get your knickers in a twist mate, so its just the yb made oil pressure quicker then on your dyno compared to the zetec ?
dont take my questions as dissing your dad mate ive already said i think its awesome and know someone who highly recommends him im just curious tis all
if i wasnt babysitting my daughter tommorrow id love to come down ive never seen an engine on a engine dyno in the flesh so to speak.
Old 15-01-2010 | 08:38 PM
  #149
paulj's Avatar
paulj
yes it is ians old car,had the car just over 2 years now
cheers paul
Old 15-01-2010 | 08:53 PM
  #150
andy130's Avatar
andy130
yes paul good to see you back, hope your doing well?
what type off box are you using?
  #151
J1mbo's Avatar
J1mbo
B1mbo
like i say, ill take pics tomoz anyway and show you and everyone else
pic of graph coming up in a second for those interested
Old 15-01-2010 | 09:00 PM
  #152
J1mbo's Avatar
J1mbo
B1mbo
power/torque curve
excuse the grubby finger prints lol
Old 15-01-2010 | 09:11 PM
  #153
paulj's Avatar
paulj
the gearbox is mtx75 area 6 special,shot/peened gears,quaife atb
don`t know if it`ll take the torque tho!!
cheers paul
Old 15-01-2010 | 10:08 PM
  #154
scoooby slayer
power/torque curve
looks awesome power, holds torque well
that focus is gonna be a beast
Old 15-01-2010 | 10:14 PM
  #155
scoooby slayer
ok, it was that graph of the yb that made me think why would one engine do it and not another. it must be that the yb could make the pressure quicker for the dyno to see it quick enough musnt it ?
Old 15-01-2010 | 10:16 PM
  #156
J1mbo's Avatar
J1mbo
B1mbo
its not the engine making the pressure quicker, its the dyno not catching up quick enough
the cossie would have been help in for longer, the focus engine was not held for long periods of time !
jim
Old 15-01-2010 | 10:28 PM
  #157
paulj's Avatar
paulj
jimbo i think the car is gonna be an absolute animal!!
cheers paul
Old 15-01-2010 | 10:30 PM
  #158
J1mbo's Avatar
J1mbo
B1mbo
i think so to paul your gonna need some slicks on her to attempt to get grip lol !
will have to take me for a spin some time
Old 15-01-2010 | 10:41 PM
  #159
paulj's Avatar
paulj
jim just wait till we map it at brunters you can take it for a run yourself,aswell no problem to me mate.least i can do!!
cheers paul
Old 15-01-2010 | 10:53 PM
  #160
J1mbo's Avatar
J1mbo
B1mbo
cheers paul
if i can fit in the seat were on lol
Quick Reply: paul johnstons mental zetec turbo (graph and pics)
