Help with Merc Sprinter!!!
Old Jan 7, 2010 | 07:41 PM
cheftony1's Avatar
cheftony1
Default Help with Merc Sprinter!!!
Ran out of diesel yesterday, no problem, had a can and filled her up.
Now it won`t start, drained the battery trying to start, tried the cold start spray but still does`nt start.
Recharged the battery overnight and tried again today, still no joy.
If anyone has any possible solutions, they would be greatly recieved.
I do have breakdown, but the van is 1 minute from home so not sure they`ll come out.
cheers
Tony
Old Jan 7, 2010 | 07:47 PM
YOREVOL's Avatar
YOREVOL
YOREVOL
they are a bastard to start apparantley ive got a vw tranporter (same thing) in the workshop have been told to tow it by vw specialists to get it going.
good luck
Old Jan 7, 2010 | 07:54 PM
Mr.T's Avatar
Mr.T
Did you let the air out of the system? There must be a handpump somewhere so you can pump until the diesel comes out. Then close it.
Old Jan 7, 2010 | 07:57 PM
JoeE30's Avatar
JoeE30
Check the fuel filter is full, if not fill it...try it then.
If it still dont fire try just loosening the unions at the injectors just to bleed any air out and try again....if its a new sprinter the alarm/imob might prevent it starting when the bonnet is open like some of the cars do....
Old Jan 7, 2010 | 08:04 PM
cheftony1's Avatar
cheftony1
Thumbs down
Thanks guys, my garage told me that it should `prime` itself after this happens, I can see an air bubble in a clear fuel pipe.
Theres no fuel getting through at all.
Will tow it in tomorrow morning.
Old Jan 7, 2010 | 08:10 PM
Mr.T's Avatar
Mr.T
Allmost every diesel needs the air removed. Just look in the instruction man. THink it will say where you can find the hand pump.
Old Jan 7, 2010 | 08:15 PM
rich123's Avatar
rich123
sounds like it just needs bleading properly if not that check the seal on the fuel regulator that will stop it running
Old Jan 7, 2010 | 08:23 PM
nickywarwick's Avatar
nickywarwick
ther is no bleeder on a sprinter, you need to fill the fuel filter up seperatly & then crack the injectors off all together then nip them up 1 by 1but make sure you nip them up befor you stop turning it over.
had loads of bother with them but doing it this way you will get it away + running out of fuel in a sprinter is not recomended as your finding out there right bastards
cheers nic
Old Jan 7, 2010 | 08:24 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
dont think there is a hand pump,they self prime, but the fuel filter MUST be full or it wont run. Mine wouldnt run after changing fuel filter, turned over forever and couldnt find hand pump, rang mechanic mate who told me to make sure filter is full, did so and it fired after a few turns...
Old Jan 7, 2010 | 08:25 PM
Mr.T's Avatar
Mr.T
Modern cars
Old Jan 7, 2010 | 08:28 PM
rostill2007's Avatar
rostill2007
we use a fuel pump off a cavalier to prime the filter and pump also if the engine is turning slightly to slow it may not start we had this problem on a zafira and it fired with a slave battery fitted
Old Jan 7, 2010 | 08:43 PM
DHMC's Avatar
DHMC
happened to me left it over night and it sorted itself out by morn lol
but i believe if you run it dry you need to pump the air out
DHMC's Avatar
DHMC
was a mondeo tho
Old Jan 7, 2010 | 08:44 PM
TIFF's Avatar
TIFF
Chasing Radders
tow it in 4th....had to do that wth my transit!!!!!
Old Jan 7, 2010 | 09:08 PM
cheftony1's Avatar
cheftony1
Danny, wheres the filter as I look at the engine bay ? Right in the middle top with 3 lines going into it ? Theres a small screw on top and one on the right hand side, when we took them off no fuel came out.
Is this where we should fill it ??
cheers
Old Jan 7, 2010 | 09:11 PM
nickywarwick
yes but take filter off & fill it,
rostill2007
cheers
take the top off if there is a paper element in there thats where to fill it may start and cut out when the filter drains though
Old Jan 7, 2010 | 09:12 PM
daviddunlop83's Avatar
daviddunlop83
Yeah try towing it first. Might take a wee bit to get it going, itll not go on the first try
I know one of the transits doesnt have a hand pump permently installed, on the ford TIS when you change the diesel filter ford have a specialist tool (hand pump) they connect temp to get it going then remove it again after, tho if you fill the new filter up with diesel it starts again fine.
Old Jan 7, 2010 | 09:16 PM
nickywarwick
lol. fords special tool is an old hand primer from an early ldv convoy. transits are piss easy to start, just unscrew the top of the filter housing & fill it brim full..
sprinters if you fill the filter briming then use a seringe to brim it full when its fitted crack of the injectors it will start...
DazC's Avatar
DazC
Cunt to bleed up.
If you have access to a vacuum bleeder ten you can remove the bleed screw on top of the filter and suck all the air out. Fantastic tool for this kind of shit.
Old Jan 7, 2010 | 09:21 PM
daviddunlop83
Lol dunno why they dont fit the pumps like they used too
Problem with this transit my friend has was he didnt fill the filter and started it and it started but quickly stopped again
Old Jan 7, 2010 | 09:24 PM
IANS2RST's Avatar
IANS2RST
remove the return line form the fuel rail from the filter. furthest toward the back of the engine as u look at from the top & aim it into a container. crank the engine & it should start. reconnect pipe then restart & loosen the bleed screw to get rid of any remaining air.
Old Jan 7, 2010 | 09:29 PM
nickywarwick
neither do i mate, friggin stupid idea ther was nowt wrong with them
dojj
Sep 29, 2015 10:32 PM
Ebonycossie4x4
15
Sep 2, 2015 11:40 PM
Dragon
23
May 11, 2005 10:03 PM
Disabled Account
18
May 11, 2005 01:39 PM
david
Nov 27, 2004 08:58 PM
