HELP NEEDED BEFORE IT GETS DARK, MK3 TALEGATE
Old Jan 3, 2005 | 03:29 PM
TONY C's Avatar
TONY C
Default HELP NEEDED BEFORE IT GETS DARK, MK3 TALEGATE
Can some one please tell me where the ball bearing thingy is for the boot light, my boot light seems to be stuck on and alarm telling me my boots open, when it's shut,
anyone????
Old Jan 3, 2005 | 03:38 PM
Stu.H's Avatar
Stu.H
ball bearing thingy?
Old Jan 3, 2005 | 03:40 PM
TONY C's Avatar
TONY C
car talk stu, now go bak to your diet question, lol
Old Jan 3, 2005 | 03:44 PM
Stu.H's Avatar
Stu.H
looks dark to me
might as well delete the post
ur problem is probably because the rear end of the car is so badly corroded, there is no catch for the boot to close onto
HTH
nthorpey's Avatar
nthorpey
Do you mean the switch that tells the light to come on when boot is opened
Old Jan 3, 2005 | 03:46 PM
Stu.H's Avatar
Stu.H
no, i think he means the "ball bearing thingy"
TONY C's Avatar
TONY C
yes, it's a ball bearing, so i've been told
Old Jan 3, 2005 | 03:47 PM
TONY C's Avatar
TONY C
stu, get in practice for your gym, go and run up and down your stairs 100 times, lol
Old Jan 3, 2005 | 04:53 PM
TONY C's Avatar
TONY C
so it's dark and no one knows??????
Old Jan 3, 2005 | 05:36 PM
Gaaables's Avatar
Gaaables
i thought the boot had pins on the bottom, which connect with a plate when the boot is shut. they normally get corroded. easy to clean off with some wd40 and a wire brush or similar
Old Jan 3, 2005 | 05:38 PM
Gaaables's Avatar
Gaaables
Old Jan 3, 2005 | 09:04 PM
TONY C's Avatar
TONY C
nope still been told it's a ball bearing
Old Jan 4, 2005 | 09:47 AM
JesseT's Avatar
JesseT
It's a mercury switch!
Old Jan 4, 2005 | 10:01 AM
EssexBoyRacer's Avatar
EssexBoyRacer
On the Mk4 tailgates (I presume Mk3 will be the same) the switch is located inside the tailgate as part of the locking mechanism (you gain access to it by removing the cover to reveal the wiper motor etc...)
Its a push switch activited by the lock its self but the clip that holds the switch is plastic and they can break - which can leave the switch in the "on" position even with the lock closed.
Old Jan 4, 2005 | 10:21 AM
Rossco's Avatar
Rossco
A mk3 Escort does use a thin tube with a ball bearing in it, sounds like the ball has got stuck inside the tube.
Take the black plastic cover off from the boot, i think the swich is on the drivers side of the tailgate, you carnt miss it. Its about a inch long and shiney with a wire or 2 comming out of it.
mk3 fiesta cosworth
Aug 23, 2015 10:31 AM
leep27
Ford Mondeo Including ST
Aug 22, 2015 01:52 PM
col93saphcos
Aug 7, 2015 03:21 PM
orionguy
Aug 6, 2015 07:36 AM
Bosch
Aug 4, 2015 05:14 PM
