Oil squirters!!
Oil squirters!!
Were's the best place to get them!??
Its only for a engine im playing with (diy expermenting) so has to be cheepish rearly!!!
Or is there any standard common'ish engines that have removable ones that i can go on the robb!!!
Cheers in advance!
Cheers in advance!
well there for a 1341 8v g60 engine im playing with!
Read a build thread were a bloke fitted them into a redtop and i always thought if your gonna do lots of mechining then why not fit some if there cheepish to buy?
hmm dint think of that!
is there anyway of working it out or is it just give it a go and see???
Dont think they would be to hard to remove if it did, or possably up the oil pressure slightly? Buy using a different pump or modding the standard pump? (i now most work on a spring dont they?)
What sort of problems can you get from to high oil pressure?
Mine will have a lot larger oil sump and hopfully some sort of gated plate so the oil in the sump and the pickup not being able to draw any oil wont be a problem?
*** Sierra RS Custard ***
They have a spring loaded ball in them that shuts them off if oil pressure drops, so no worries there.
They are from an isuzu 1.7 TD engine, if you call autovaux and tell them you want some like in the Total Vauxhall article, they will know what one you mean, about 30 quid a set.
If you mean a redtop vauxhall lump it was probably me with the ones for my nova:
I read through your thread but didnt see any more photos
http://www.vauxhall-sport-forum.com/...ters-t265.html
Your drift them in, you need to be careful not to damage them, its important to drill or ream the whole to the correct size.
We found they worked best at 5.85mm IIRC
edited to say : there are some right spaz's replying on that thread chipper, especially the later pages
Fantastic chip!! Yes mate it must have been your thread, ive read so many over the years i forgot it was yours!
Dont supose you have the part number for them as i work for a parts place so should be able to source them though work!
why out of intrest did you chose those ones???
I dont know the part number off hand but im sure I can find it out for you.
I used them because they are tried and tested and readily available, and when I ran the idea past Stu @ MSD years ago when I first did it in about 2005 or so, he said that he also had used them with good success on things like RS turbos, so that seemed like a good endoresement.
We use them in quite a few engines in the vauxhall world now, Rob's astra also has them for example and thats certainly taking a massive beating for a home made effort!
deathrider666
28-09-2015 06:12 PM
