Rollcage for Cossie
Sierra Cosworth CDS M/Point SC1/90 Ł485.00
www.customcages.co.uk
Thats just 1 place doing them seeing as you asked
Now if you expand and tell us what type of cossie, if you want weld in, bolt in, or velcro then im sure there are other alternatives which you could choose from
So you don't want a Roll cage... you want some shiny metal Tubes in the back of your car. Have you considered Jumbo sized Toilet rolls and some silver paint?
PMSL, that or the bendy foam pipe lagging!!
1st to 200 without NOS
Originally Posted by JimRS
the cage is for a sapphire 4x4! half cage and i want a show 1.
Its little 'Tuners tips' like this that make PF what it is today.
No problem ARMOURER,
Peter Lloyd does a Safety Devices 6 point bolt in for Ł409, Custom Cages and Roll Centre do weld in cages for around the Ł485 mark HTH
Bear in mind there are different types of tubing available which will affect the price. It should be a minimum of CDS tube 38mmx2.5mm, 42mmx2mm or 50mm x 2mm. The next and more expensive stage up is T45, which is special lightweight tubing but retains strength.
If you contact them ask them exactly what your getting or what they are quoting for
I remember seeing that once in a Maestro
thats a great tip PORKIE, I see you both went for the blue ribbon option instead of seatbelts, Mmm very attractive.
But seriously why have even more crap stuck in the car to cause injury in the event of an accident, if its there it should work/ do something and not just look good surely?
Russ Payne
25-09-2015 08:29 PM
