Screamer pipes!!!!!!!!!!!!
Ello all! Happy New Year!
Ive just seen a few pics in peformance ford mag of a S2 wid a modified downpipe! its got an extra pipe on the waste gate! is there any advantage wid havin this and whats the costs??????????
Daveyboy(AKA Pie crust smasher)
Sweet, i already got a 2 1/2 inch wid 3 inch tail pipe, which i ve debaffled! that sound beefy when comes on boost! what does it pop and bang?
Can this be adapted to my T3 cos i ve not long brought a stage 3 hybrid and it would be a shame and a waste of money to change! also anyone know prices?
a screamer pipe is only used needed on cars equiped with an external wastegate.
Yours will have an internal actuator controlled wastegate
no is the answer to your question you cant fit it.
you would need a custom manifold new much larger turbo with no integral wastegate and the external wastegate itself
It Wasnt Me!
Craig, u can ahve them without an external wastegate, you just need a custom flange, take the origonal elbow off the T3, bolt on the custom flange.downpipe, i'll show u a pic. .
It Wasnt Me!
Craig, im getting one made for £30 lazer cut flange etc, mates doin the flange and welding etc. well give him a tenner for his trouble (cheeRS Rab) lol want some sort of valve in it so i can turn it off tho when it does me tatts in
#1 in Spelling Club
Originally Posted by CraigN
all that money just for a screamer pipe that makes noise :gayflag:
I could go on......
The purpose of venting the Wastegate separately, whether it is Internal or External, is to take the strain off the exhaust. Even if you re-introduce it later on to keep the noise down. The first section of the exhaust and in particular the bends are under alot of pressure under boost and any way that you can relieve the strain is a benefit. Its a basic engineering principle.
The one that I am selling on Ebay (as per the original discussion) can be used in more than one way. It can be used as an External Wastegate Vent (Screamer Pipe) or the pipe can be put back into the exhaust roughly where it ends if the noise is too much, but will be more free-flowing than it would have been without it.
I no longer use it for a number of reasons. The main one is that I had my fun, but I now want the car to be more civilised, which it is as a result of the new exhaust. It is alot of fun and the good thing about it, unlike a Dump Valve is that it is only noisy at high boost (once the wastegate has actually opened).
Dont be mislead anyone, it isn't an easy conversion and certainly isn't for someone who wants to bolt it on and forget about it. That pipe cost me well over £200 to develop and it went through several incarnations. The flange alone was £70 as the only real option at the time was to buy it from HKS because we really weren't 100% sure of what we were playing around with. The dividing piece that separates the Turbine Outlet and Wastegate cost around £100 to make, because I had to have an engineer make it 'live' (cutting/filing etc rather than laser cutting) because the inside of a Turbine Housing is an irregular shape and because they are cast, they all differ a little (hence the wording of my auction).
Hope this helps.
Fucking superstar........
I could go on......
Hope this helps.
I've done one before, and I'm fairly adept with machining etc. Shouldn't be a big deal, I've done much more complicated things on ships because if I didn't we don't move any more
I'll drop you a PM with some details etc when I get home and you can point out my errors for me.
07-10-2015 12:56 PM
