Help!!!!! sierra cossie
just purchased a 3 door sierra just wondering does a sapphire cosworth 2wd rear axle with disc brakes and lsd fit a 3 door sierra without having to do any work?
? or is there any problems with attaching one because three door rear axles are impossible to find!!!!!!
there all the same as far as im aware except 4x4 rear beams not 100% sure on the 4x4 one tho , just as easy to get a cossie diff a 2nd hand set of cossie trailing arms , the beam its self is the same so no real need to pull it all off to swap it
yes but it is running a standard sierra axle with drums and its the rear discs mainly that i am wanting to do the swap for because i myt aswell get the entire axle with diff and all if its no real hassle
mike elsome
14-09-2015 04:08 PM
Adam Graham
06-09-2015 06:04 AM
