Homemade valve spring compressor
Hi,
I was looking on ebay at the valves spring compressors and it thought that i would be easy to make one. Not that im cheap just thought twood be easy.
I got a piece of square tubing and drilled 3, 7.5mm holes in each side about 12mm apart. Then i cut out the waste and made two slots in each side, both big enough to get out the retaining collets and be able to get a small magnet in to take out the collets. Then i welded on a strong washer to the end so i didnt damage the retainer.
Then i got a strong clamp and clamped the compressor to the valve and clamped as far as it would go, with ease, and once the collets were slipped off i put in the magnet and took them out. Took off clamp and valve spring removed, oh yea quality
Make sure you have a good quality clamp as you dont want one that will let you down.
What do ye think, the total cost was 20cent.
Anyone else make anything like this?
http://s742.photobucket.com/albums/x...t=IMG_0069.jpg
http://s742.photobucket.com/albums/x...t=IMG_0071.jpg
http://s742.photobucket.com/albums/x...t=IMG_0072.jpg
have you made it for a CVH head . if so for £8 you can get one of these and they are just the job as you can do the valve steam seals on a CVH with the head on the car
http://www.justoffbase.co.uk/Valve-S...H-Sealey-VS150
SMILER258
28-09-2015 09:04 AM
