Got my MSD chip but ............ Sorted
Old 05-12-2009, 09:22 PM
  #81
JTECH James
Passion for Fords!
JTECH James's Avatar
Originally Posted by pee vee
there are LOADS of aftermarket parts that dont fit cars how they are supposed to
i bet 75% of uprated bits dont fit anythin like as good as OE parts that they replace..people hardly ever moan about that.
to be honest, I didnt really think twice when i got my MSD set up and had to do this to it.. If Stu or James etc did this before you saw it,, you wouldnt even realise it was an issue i bet!
am i right in thinking its only the closed loop set up that uses this board that needs to be cut.
very true, yes generally its the more advanced software that we encrypt like this
our p8 stuff doesnt need a std board so they fit straight into those
Old 05-12-2009, 09:25 PM
  #82
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Its just people being anal, than it actually being an issue because it isn't is it?
Old 05-12-2009, 09:26 PM
  #83
RSCossieGaz
RSCossieGaz's Avatar
Originally Posted by BIG TONY RS
Cant believe how this thread has turned out all i wanted was a simple answer and thats it instead i get Paul saying my little bit of handy work is a bodge i agree it does not look 100% but believe you me that little circuit board is under no pressure and is very very sturdy in place and just by fitting this chip alone my car instantly runs so much better cant believe it and im very very happy with it
Tony
you been out in it yet?
Old 05-12-2009, 09:28 PM
  #84
JTECH James
Passion for Fords!
Tony
thats good to hear
Old 05-12-2009, 09:40 PM
  #85
Lambchop
PF Idiot Sniper
Lambchop's Avatar
Originally Posted by James @ M Developments
ahh ok, you obviously fit more than i do then, because the 5 or 6 a day i fit are perfectly secure. but what the hell would i know
when its fitted the board has no movement, so even with 30 screws you wont gain anything.
i said i fit 5 or 6 a day,
i didnt say i cut and mod 5 or 6 a day,
i may fit a few chips to one ecu in a day, or the emulation equipment,
riiiiiiigggggghhhhhhhhht.
talk about misleading
Old 05-12-2009, 09:44 PM
  #86
Gary F
Gary F's Avatar
I agree with Paul tbh...
Old 05-12-2009, 09:47 PM
  #87
JTECH James
Passion for Fords!
what a shock
Old 05-12-2009, 09:49 PM
  #88
Gary F
Gary F's Avatar
Old 05-12-2009, 09:58 PM
  #89
Dan@Rapid-Ford
Dan@Rapid-Ford's Avatar
this place is full of ex-spurts,
ex= a has been
spurt= a drip under pressure
Regardless of the product do you not think this is a bit of a "Ratner" statment insulting a customers - bearing in mind the company you work for gets a lot of work off the users on this board?
Old 05-12-2009, 10:00 PM
  #90
boost mad
boost mad's Avatar
PCBs are stronger than people give them credit for especialy the 1.6 that i think they are.
If you dont like the way it looks then get them to fit it and never open your ecu
Mines fine !
Old 05-12-2009, 10:02 PM
  #91
JTECH James
Passion for Fords!
Dan im off duty,
only if its taken in completly the wrong way,
im very good freinds with lots and lots of people on here, and have been for a long time before i worked at msd
lets aim my comment at them, as i know for sure they will know how it was meant to be taken
i thought it was quite funny, but i like a laugh,
and this smilie > normally means im joking
Old 05-12-2009, 10:30 PM
  #92
KSA-Cossie
KSA-Cossie's Avatar
Originally Posted by BRAMMER
Got the same fitments in mine apart from MSD cut my board to fit and i've never had an issue and it's a clean enough job - i'm a happy customer
Me too chris.
Old 05-12-2009, 10:33 PM
  #93
KSA-Cossie
KSA-Cossie's Avatar
There endeth the lesson
Old 05-12-2009, 11:20 PM
  #94
SS1
SS1's Avatar
Will post when i get all the
Old 05-12-2009, 11:26 PM
  #95
Twellsie
Twellsie's Avatar
not sure what all the fuss is about tbh, for all i care you can paint it brown and write shit on it, so long as it makes the car faster, who really gives a fuck?
Old 06-12-2009, 07:47 AM
  #96
GUZZLER
GUZZLER's Avatar
i've seen a few ecu's where people have 'peened' out the lid so it has a raised section for the chip to sit in & still be fixed to the ecu the way it was.
for the people who don't know, this mod only applys to L8 ecus as fitted to the 4x4 saff, the 2wd ecus L1 & L6 have the chip fitted in the main board!
Old 06-12-2009, 09:58 AM
  #97
Dan@Rapid-Ford
Dan im off duty,
"Ratner's speech is still famous in the corporate world as an example of the value of branding and image over quality. Such gaffes are now sometimes called "Doing a Ratner", and Ratner himself has acquired the soubriquet "The Sultan of Bling". Ratner has said in his defence that it was a private function which he did not expect to be reported, and that his remarks were not meant to be taken seriously"
boeb
09-01-2020 05:11 AM
tankybaby66
06-02-2016 02:24 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
tib2220
14-09-2015 12:33 PM
Quick Reply: Got my MSD chip but ............ Sorted
