What is usually the first thing to let go......
02-12-2009, 09:05 PM
when tuning a YB?
Head gasket? Rods? etc....... I'm wondering how much certain parts of the engine would take before needing changing when pushing towards the 400bhp mark?
Is there a list of sorts that should be addressed, any weak links?
02-12-2009, 09:10 PM
head gasket is a must
rods will go on for well over 500hp
02-12-2009, 09:14 PM
very very very rare for the rods or crank to let go on a yb!in fact generally the yb lump is a stong old thing,its usually the wiring that lets it down causing melt down!
Although having said that headgasket is a weak point as all ready said and at high power the blocks get throw abit of a paddy
02-12-2009, 09:15 PM
your wallet
02-12-2009, 09:22 PM
Quote:
Originally Posted by
rsnissan
your wallet
Was thinking that! lol
Head gasket suggestions?
02-12-2009, 09:23 PM
Billy_RST
grp a
B1mbo
Billy_RST
when tuning a YB?
head gasket and turbo if pushiong a t34 to 400hp
as for headgasket, we in most cases use a wrc one
jim
02-12-2009, 09:33 PM
J1mbo
jim
We?
02-12-2009, 09:35 PM
B1mbo
Billy_RST
We?
sorry mate, my old man havery at scs, i say we as its easier than explaining this every time
It Wasnt Me!
Billy_RST
What is usually the first thing to let go...... when tuning a YB?
The Wife.
Buy a Skyline, spend less cash and have more power
02-12-2009, 09:36 PM
If used hard on a track a baffled sump is something to look at, std setup is a weakpoint i believe.
Billy_RST
We?
as in harvey gibbs of scs jimbo is his daily reminder of his drunken mistake one night many moons ago
02-12-2009, 09:39 PM
B1mbo
mechanic28
TOSSER !
pmsl !
02-12-2009, 09:44 PM
haha! Ok i didn't realize.
Do you need to do head work or cams for 400bhp?
Would you recommend using arp head studs with the wrc gasket?
Im new to Cossie's so really want to make the least mistakes as possible!
02-12-2009, 09:46 PM
opposite lock
most standard sumps are not suitable for track use mate, most cars will need a baffled sump for dedicated track use
02-12-2009, 09:48 PM
Baffled sump is a bit ott for what i want mate. Cheers anyway.
Billy_RST
standard head will do 420/450hp so you'll be ok there
standard head bolts and a grp a head gasket
J1mbo
TOSSER !
pmsl !
02-12-2009, 09:54 PM
fuel pump rewire is a must as well mate
02-12-2009, 09:56 PM
I keep hearing about fuel pump rewire. Is there something im missing? Why not use an 044?
02-12-2009, 10:01 PM
rewire is required as the wiring has prob gone shitty which causes voltage drop,even more so under load i.e at high boost!which will cause the pump to stall thus melting ya engine
02-12-2009, 10:06 PM
Fair enough
03-12-2009, 06:32 AM
TT T38 Power
Billy_RST
Im sure it draws my current than the standard pump so will show up your old poor wiring even more.
When i changed my wiring i gained just under 2v at the pump.
Steve
03-12-2009, 09:30 AM
Billy_RST
the pumps are different on a esc (internal) to a saff (external)
Also a reliable 400bhp is a lot harder to get than a reliable 370ish turbo wise and reliable 400 will have potential to be easy 450 and if you have the hardware for 450 why not use it
Goodluck and welcome to cossie ownership
03-12-2009, 06:32 PM
I would also say wiring and head gasket.For what it takes to repair these its a nice bit of peice of mind.
03-12-2009, 06:44 PM
the first 2 mods i made on my saph where the 044 pump & the re wire
03-12-2009, 09:43 PM
Nice one lads.
07-10-2015 12:56 PM
Mark_
40
02-10-2015 04:40 PM
Fudgey
21
30-09-2015 06:19 PM
rsguy
44
29-09-2015 03:29 PM
