Reset clutch pedal
Old 03-12-2009 | 09:35 PM
mechanic28's Avatar
mechanic28
Question Reset clutch pedal
how do you reset the clutch on the cossie?pulled the pedal up to release the cable to get the box out etc,but now the pedal sits higher then the rest of the pedals now! bloody thing!it has clicked a few times when pressing it down!just wondered if it can be reset?
Old 03-12-2009 | 09:41 PM
B13 JUS's Avatar
B13 JUS
lift the pedal again and get someone to give the cable a little pull. then press the peddle a few times. that should be reset
Old 03-12-2009 | 09:42 PM
mechanic28's Avatar
mechanic28
can i pull the cable from inside the car as i lift the pedal or does it have to be box end?
Old 03-12-2009 | 09:43 PM
B13 JUS's Avatar
B13 JUS
also are you sure the cable is locate into the block properly? no sitting on the edge?
Old 03-12-2009 | 09:44 PM
B13 JUS's Avatar
B13 JUS
when i do mine i give it a little pull where is goes through the bulk head.
Old 03-12-2009 | 09:45 PM
andrewg's Avatar
andrewg
it should reset everytime you use it unless the stop for the return position is bent thats what releases the rachet
mechanic28's Avatar
mechanic28
i presume you mean box side where the cable goes goes into the fork/arm?with regards to the cable sitting right?tbh i aint checked that
Old 03-12-2009 | 09:46 PM
mechanic28's Avatar
mechanic28
nothing should be bent as i aint touched anything to bend it
Old 03-12-2009 | 09:48 PM
B13 JUS's Avatar
B13 JUS
another way to do it if you don't have anyone to help.
pull your pedal up then with your other hand give the rachet a push, then press the pedal.
it will click a few time then stop where it should have been before
Old 03-12-2009 | 09:49 PM
B13 JUS's Avatar
B13 JUS
yes mate where it goes through your engine block itself. (thats the outer part of the cable)
Last edited by B13 JUS; 03-12-2009 at 09:53 PM. Reason: did'nt read your question properly
Old 03-12-2009 | 09:53 PM
andrewg's Avatar
andrewg
its self adjusting rachet and it re grips it when you press the pedal,, you should never need to do any thing unless somethin is not right,,
the bracket tha holds the outer at the b/head is good for cracking and also bushes in the pedal were and breaK,, and also sometimes teeth come of the rachet
Old 03-12-2009 | 09:56 PM
B13 JUS's Avatar
B13 JUS
when the teeth come of the pedal sits lower does'nt it?
Old 03-12-2009 | 10:00 PM
andrewg's Avatar
andrewg
can do and also sometimes may jump to the floor,, uprated clutches usually shorten the life of them
Old 03-12-2009 | 10:07 PM
B13 JUS's Avatar
B13 JUS
mechanic28 has a high pedal, so i thought its racheted up to far for some reason or his cable is snagged up somewhere
Old 03-12-2009 | 10:08 PM
dojj's Avatar
dojj
Resident Wrestling Legend
push the pedal as far down as you can
then side step the clutch to let the pedal bang back up again
press it again and it will be ok
hopefully
Old 03-12-2009 | 10:12 PM
andrewg's Avatar
andrewg
hopefully
that will def bend the return stop
the only way it will sit higher is if the stop is bent,, thats what stops it coming right up
Old 03-12-2009 | 10:13 PM
B13 JUS's Avatar
B13 JUS
hopefully
never tried that before but thinking of it, it will work. i'll try that the next time i need to do it
Old 03-12-2009 | 10:52 PM
mechanic28's Avatar
mechanic28
cheers for the info lads will give it a crack tomorrow and chack to make sure the return stop is all ok
mark94
Ford Mondeo Including ST
10-10-2023 07:52 PM
arkeye
Ford Focus ST
20-02-2016 02:22 PM
