Who makes Proper strong Actuators?
01-12-2009, 05:08 PM
Anyone know the best supplier of a good strong [as in spring poundage!] actuator??
01-12-2009, 06:55 PM
PassionFords Creator
01-12-2009, 07:08 PM
i need to order a -34 as a small sleave has come off mine and it works but the bar vibrates.
actuators
Quote:
Originally Posted by
Stu @ M Developments
How strong do you want?
Hi Stu, tried a few times to ring yours this afternoon, line was busy! It must be the Sale on !! Got my motor on the rollers today,Getting peak at 1.8 for a second then it falls off badly! my -34 is opening at 1 bar when tested with minivac.I know the boost will fall off but Need one that will hold 1.8 to 2 bar ish for as long as poss. Fit is T34 on a 4x4 manifold.
Many thanks. Richard
01-12-2009, 07:15 PM
Try Forge motorsport
01-12-2009, 07:17 PM
Air injectors might be a useful addition here?
01-12-2009, 07:30 PM
Testing the future
as said, either bleed on or off to achieve the pressure you want (to some extent) regardless of the spring rate
01-12-2009, 07:47 PM
OK, I am going to get a boost controller to help things as well, Got a bleed valve at the min!
01-12-2009, 08:20 PM
air injectors mate its a very good way of controling high boost on a cossie
01-12-2009, 10:00 PM
you'll end up bending the wastgate arm then the penny won't seal and you'll have loads of lag
01-12-2009, 10:47 PM
andrewg
or snapping the arm completely.... which is not uncommon really on the T series turbos.
01-12-2009, 10:48 PM
#1 in Spelling Club
I have a practically brand new one with a base pressure of 24psi. It has an offset rod though. Not sure what you're configuration is like?
JK12
33
26-04-2021 12:09 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
gingeRS
04-09-2015 06:29 PM
