4wd cossie uprated calipers (4pot)
hi, does anyone know if its possible to get a pair of 4pot calipers that fit standard size disks (i.e under the 15" wheel)
Not fussed what brand they are be it hi spec, ap, wilwood etc
The reason i say this is because ive got a mk1 fiesta, have 15" wheels and currently run a bolt on setup which consists of mk5 rs2000 discs, and 4wd calipers. I just want a bit more clamping power ,plus they tend to look alot better and i need as much braking as i can get........
I do sets of these if it helps at all ,New calipers, & New pads inc the vat for £400 delivered !!!
https://passionford.com/forum/trader...-and-pads.html
I have just fitted cossie 4 pots to my s1 you need to mill 3.75 off the caliper, and the bolt holes do not line up, you also need to space out the s1 wheels by 15mm. buy the time I paid out for these, i would now go for the hi spec bolt on jobs, also i dont know regarding the mk1 fiesta, hope this helps, good luck!
