Basic ingredients for a 330bhp YB?
I'd prefer to run a standard clutch on 330 horse as its a lot nicer to drive. They may not last as long but lot nicer. Your engine won't require any internal mods as the YB is a de tuned engine any way.
I would like to build an engine for my 3 door someday, aprox 330-350 bhp. So a shoppinglist would be nice
So far on my list:
- 200 block (want to do the rebuild myself)
- greens
- 3 bar map sensor
- mongoose exhaust
- good chip (wich one?)
- rebuild T3
- -31 actuator
Are updated fuel / oilpump needed? and a breather kit?
Any comment is welcome
So far on my list:
- greens
- 3 bar map sensor
- mongoose exhaust
- rebuild T3
- -31 actuator
Roy, T34.48 would suit better mate if going for 350, it,d be REALLY punchy too, re-wire your fuel pump that,ll do the job, Head Gasket and again i,d go for a clutch if looking for 350...
Or just go for the NMS Gunship, i can highly recommend it
-Standard YB
-GRP A head gasket
-T34
-Greens
-Breather
-4x4 cooler (minimum)
-Chip (MSD or similar)
-Clutch
-3 Map bar Sensor
--31 actuator
that's if you want a genuine stage 3
-GRP A head gasket
-T34
-Greens
-Breather
-Clutch
-3 Map bar Sensor
--31 actuator
I didn't think cossies needed so much work to get that sort of power?
so i take it all those mags featured cossies that only had a chip were no way close to 300bhp then?
But generally folks change to a T34 for going 330+, again different housings, injectors to suit your level of tune.
greens
3 map bar
t3
standard intercooler
chip
gob load of boost
but how long is it going to last?; t3 will be screaming, the engine wont breath properly, ACT will be high, the head gasket will shit itself, the clutch might slip, shit chip which over fuels or runs lean....etc
so if your going to do it, do it properly or it will all end in tears. This is why cossie's got a reputation it didnt deserve. Bill & Ben the flower pot men doing what i've just typed on a sunday afternoon in their shed.
330BHP would be better on a larger turbo such as T34, not sure about rebuilding of engine, just as long as the engine is healthy. Gunship stresses components massivly, the standard injectors for example will be over 90% duty hence why engine/components need to be healthy.
Martin
Martin
s/s exhaust
air filter
standard yb engine
grp A heagasket
Dark green "803"s injectors or 55lb black seimens
-31 actuator
3 bar map sensor
T3 turbo in tip top condition or a T34.48
4x4 intercooler or rs500 style intercooler
oil breather
standard clutch or for peice of mind 6 paddle clutch plate with standard cover!
air filter
standard yb engine
grp A heagasket
-31 actuator
3 bar map sensor
oil breather
my 2wd saph made 333.2 peaking 26 holding 21 with equal torque
low milage bottom end
A1 stage 3 chip
group a head gasket
air filter off my s2
greens
3bar
t34.48
radtec 500 cooler
ryan engine loom
re wired 044 pump
mongoose full system
ford standard clutch
and went like fuck
A1 stage 3 chip
group a head gasket
greens
3bar
t34.48
radtec 500 cooler
ryan engine loom
re wired 044 pump
and went like fuck
Greens, Suitable chip, good 500 IC, 3 bar, T34.63 (dont think i've saw a genuine 330bhp with a .48 but no doubt everyone else has) 3" exhaust, std airbox, -31 and 28psi
oh and some BCR 8ES for some good sparkage.
As above, if an escos, uprated walbro...
.48 should piss 330 imho!although greens wont cope with 28psi of held pressure
Mechanic28, 28psi not held just peak. wether greens would be able to hold 28psi I dont know...
Pacwest, know feck all about comp maps, all I can go by is what i've witnessed on numerous cars...
figures do seem to rise south of the border tho
fair play i doubt greens would be able to supply enough fuel at 28psi,they seem to start to throw a wobbly at 23psi lol!
