rear camber wedge's for sierra back axle
hi does anybody know where I can get a set of wedges to change the rear camber on a sierra cosworth backaxle I have fitted to a p100 at the moment to get it to sit at the right ride height its runing 3 degrees of camber would like to get it back to pretty much standard
I have seen them for sale on e bay
have also been told some people use washers but dont fancy doing it that way
They are normally used for toe correction on the really crappy sierra back end, but could be used for camber if fitted at top instead of rear on hub.
You could also just use a thin strip of metal to do the same.
![Name: Photo-0016.jpg
Size: 14.8 KB](https://passionford.com/forum/attachments/general-car-related-discussion/167337d1502131792-rear-camber-wedge-s-for-sierra-back-axle-photo-0016.jpg)
![Name: Photo-0017.jpg
Size: 13.9 KB](https://passionford.com/forum/attachments/general-car-related-discussion/167338d1502131792-rear-camber-wedge-s-for-sierra-back-axle-photo-0017.jpg)
Give me a pm, will put you in touch with my supplier.
Puller of the Wrench
I prefer a half tank of gas, me in it and the alignment shop making the rear end zero in all respects. I just like how my stick rear beam works when zero'd.
![](https://img.photobucket.com/albums/0803/Taps56/Camber%20shims/Photo-0014.jpg)
The shims correct the camber and if you look closely they alter the track as well alter one your alter the other
![Name: Reartrack2.jpg
Size: 45.5 KB](https://passionford.com/forum/attachments/general-car-related-discussion/167339d1502131792-rear-camber-wedge-s-for-sierra-back-axle-reartrack2.jpg)
If the shims(pictured) are on a purely flat angle, and do not have two angles it depends where you fit them as to what they alter.
I only know my camber was 3 1/2 as that is what it was measured at at Elite.
Rock Out!!
the rear plate part of the wishbones is quite week, i slammed mine square on and bent it right in ![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
![](http://i16.photobucket.com/albums/b13/bazwalton/bentwishbonespring091.jpg)
it will have to be re-made at some point, but for a quick agricultural fix, a couple of washers straightened her out
[quote=baz walton;4539523]the rear plate part of the wishbones is quite week, i slammed mine square on and bent it right in ![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
![Name: bentwishbonespring091.jpg
Size: 63.3 KB](https://passionford.com/forum/attachments/general-car-related-discussion/167340d1502131792-rear-camber-wedge-s-for-sierra-back-axle-bentwishbonespring091.jpg)
DOES THE AXLE OFF THE FROG EYE FIT THE BACK END OF A SIERRA?
[QUOTE=Taps;4536459]If these are what your after
Attachment 167337
Attachment 167338
Give me a pm, will put you in touch with my supplier.[/QUO
hi were can i get these
Attachment 167337
Attachment 167338
Attachment 167337
Attachment 167338
Attachment 167337
Attachment 167338
i seen some on ebay for about 30 quid but when i askd him about them he said there just 3mm plates not wedges so i dont no how they would work if there not tapperd
track.focus'd
12-08-2015 05:53 PM
