turbo damper
willa turbo damper fit on a 4x4 manifold ? i know the real need for one is to take the wight of the turbo on the 2wd manifold but i wondered if they fit the 4x4 as well ?
i understand there not needed but just thought any thing that help support the turbo should help the manifold and head in the long run , just wondered as i'm looking to go for a t38 turbo and thought it may help with the weigt
The 2wd damper was added at Southampton Uni, when they did the NVH tests, not because of the weight.
Cracked manifolds can be repaired perfectly without welding, as can any cast, by any amateur using HTS528, it's what NASA and BOEING use after all.
i fully understand why they were fitted to the 2wd manifold just wondered if they could be fitted to the 4x4 manifold one because i like the look of them and also just thought it may help if just a little bit but mainly because i like the look
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
if you are just doing it for looks then how about something along the lines of :
http://www.mcgillmotorsports.co.uk/i...&productId=300
bit of a bracket off the cam cover bolts and you're done
JK12
33
26-04-2021 12:09 PM
